jeff9366
Super Star Member
- Joined
 - Jan 14, 2011
- Messages
 - 12,787
- Tractor
 - Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
New to the forum, and looking at purchasing a RK24 or 37 to maintain my 20 wooded acres in southern Indiana. I have to maintain a gravel driveway with a 19 degree/35% slope, and am concerned if the 24 will be able to pull a box scraper up that angle without issue? Any thoughts from the group?
Other uses for the tractor are general firewood processing, brush hogging, trail maintenance, etc.
RK24, like other subcompact tractors, has only 9" of ground clearance. You will often high-center in woods. (5" hole + 4" tree branch = 9")
RK24, like other subcompact tractors, is available only with a two (2) range HST transmission, limiting power transfer to wheels at all times but especially when performing ground contact applications dragging up a slope.
Buy once, buy right. Minimally the RK37.
RK Tractors RK24H
2017 -
Sub-Compact Utility tractor
TYM built
Distributor: RK Tractors (a part of Rural King)
Manufacturer: TYM
Type: Sub-Compact Utility tractor
Original price: $10,499 (2017 )
RK Tractors RK24H Power
Engine (gross): 24 hp
17.9 kW
PTO (claimed): 18.8 hp
14.0 kW
RK Tractors RK24H Engine
Yanmar 1.3L 3-cyl diesel
Transmission
Type: hydrostatic (2-range)
Fuel tank: 5.8 gal
22.0 L
Mechanical
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post ROPS.
RK Tractors RK24HHydraulics
Valves: 1
Pump flow: 4.18 gpm
15.8 lpm
Total flow: 6.95 gpm
26.3 lpm
Steering flow: 2.77 gpm
10.5 lpm
Tractor hitch
Rear Type: I
Control: position control
Rear lift (at ends): 1323 lbs
600 kg
Rear lift (at 24"/610mm): 1058 lbs
479 kg
Power Take-off (PTO)
Rear PTO: independent
Clutch: electro-hydraulic
Rear RPM: 540 (1.375)
Mid RPM: 2000
Dimensions & Tires
Wheelbase: 57.5 inches
146 cm
Weight: 1610 lbs
Ground clearance: 9.4 inches
RK Tractors RK24H attachments
60" mid-mount mower deck
front-end loader
Attachment details ...
Electrical
Ground: negative
Charging system: alternator
Charging amps: 40
Battery volts: 12
Page information
Last update: September 20, 2020
Copyright: Copyright 2020 TractorData LLC
Contact: Peter@TractorData.com
Five reasons owner/operators trade up from Subcompact Tractors:
More tractor weight.
More FEL lift capacity.
More ground clearance.
Three-range (3) HST (Lower LOW, Higher, HIGH) ~~ rather than two-range (2) HST.
More tractor power.
