400cx Broken Piston Rod
/ 400cx Broken Piston Rod #1
Jchandler21
JD 4320 Cab
Hey guys. Just thought I would see if anyone has ran into any issues with the JD 400cx loader. Got a text this morning from my father-in-law about the FEL on his tractor. Apparently he broke the bucket tilt piston. Anyone run into this before?
/ 400cx Broken Piston Rod #3
Did he hit or push something with the bucket /forks tipped all the way down ? Most of the time it bends the rod or linkage not breaking the rod like that by back dragging..
/ 400cx Broken Piston Rod #4
I meant to add a question mark at the end of my sentence :), "Caused by backdraggin the bucket?".....Mike
/ 400cx Broken Piston Rod #5
This is not a common failure. Generally this failure is a result of utilizing the loader incorrectly, such as back dragging with bucket edge, digging with pallet forks, driving forward with the pallet forks making contact with a stationary object, or other action outside of the performance envelope. When the cylinder is at full extension it is at its weakest point. It would be interesting to hear what action was being performed when the cylinder broke. However based off the break on the rod, I am going to guess it was not "normal" use.
The weird thing is, it broke half way down the rod. I know its from him beating the crap out of the tractor. Just thought it would bend before it broke. In fact I've seen him run the bucket into a stump to get it out. 🤦*♂️🤦*♂️. It finally gave up when they were turning over the burn pile this morning.
/ 400cx Broken Piston Rod #7
expensive misuse considering the other side it probably bent so he needs 2
No doubt. Thats what happens when you have more money than brains. I cant tell ya the last time he has greased the machine.
/ 400cx Broken Piston Rod #9
Wow some people just never learn, A new piston is probably $$ but he has it so no big deal......
/ 400cx Broken Piston Rod #10
32 years of back dragging here and never broke anything. In fact I've never heard of it being a problem.
/ 400cx Broken Piston Rod #11
Really..... Me as well. I couldn't begin to guess how much abuse I've given my loader over the years, back dragging being one method. After over 3000 hrs. I've done nothing more than blow a hydraulic hose on the loader assembly. Mine is a KMW ML112 made in USA.
/ 400cx Broken Piston Rod #12
If you are just back dragging no problem. It’s when you have the bucket dumped quite a bit and go forward and hit something that bad things happen.
Swict 66" Bucket (A62183)
Swict 66" Bucket...
Hydraulic Hoses (A62183)
Hydraulic Hoses...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
40' High Cube Multi-Door Container (A62183)
40' High Cube...
LOT OF 17' TIN (A63290)
LOT OF 17' TIN...
