Deere 110TLB
/ Deere 110TLB #23
Look for a trailer at the same time.
Nice Diamond C. They are taking over the trailer world! I have a 25' FMAX 210SS and a 12' UTV trailer. Wanted to go with 8k torsion axles vs 7k but the 10K hutch was about the same price so I went for the extra beef. I do have a class A CDL however.
/ Deere 110TLB #24
I looked around a while before settling on the Diamond C. They are good. Glad to hear you had good experience with yours!
/ Deere 110TLB #25
My 110 fits nicely on 18' PJ with tilt up ramps, 12k rated de-rated to 9980.
/ Deere 110TLB #26
Gotta be mighty close, at 9980 trailer GVW.
JD 110 weighs 7600 lb. (+ fuel).
That leaves only 2380 lbs. for 18' trailer wt.
Maybe......but VERY CLOSE.
My 20' 14K "Quality Steel & Aluminum" trailer weighs 3,300 lbs. can't quite imagine that a 2' shorter trailer actually weighs 920 lbs. less.
/ Deere 110TLB #27
Trailer is a 12'000 pound trailer but is tagged in California at 9980 pounds.
The reason for the under 10k tags is to avoid requirement for commercial drivers license which kicks in at 10,000 pounds excluding recreational vehicles...
One of the docs has a huge 5th wheel trailer and 3 axle boat trailer... no special license needed but if I tow a 12k empty flat bed I need a commercial license.
Trailer and 110 sold new as a package with tie downs etc...
/ Deere 110TLB #28
Oh.....I completely understand the reason for derating.
My point is, that if you were actually weighed on DOT scales, wouldn't you be on the ragged edge of an overweight fine?
/ Deere 110TLB #29
Could be... original owner was weighed once on portable scales and OK
Maybe the tongue weight saved the day... he towed with 1 ton Dodge Flatbed...
/ Deere 110TLB #30
Good point!
I neglected to consider the tongue weight.
/ Deere 110TLB #31
Here is the 110 on my "Best Trailer INC" 18' with flip up ramps trailer. Never did go though a CAT scale with this setup, only towed it once. Note that the trailer had two 7K drop axles, with ALCOA 16" forged Aluminum wheels and Good Year G614 "G" rated 14 ply rating 110PSI tires. Also here is a pic of my current setup with the 545D. 15K trailer axles, 8ish K rear and 5K front was the weight with that load.
/ Deere 110TLB #33
View attachment 685096View attachment 685094
That "Best Trailer INC" works just fine as in your picture.
Most, however, would be hauling a 110 with hoe attached, and an 18' deck is just too short for that.
Your Diamond C goose neck is a first class piece of equipment.
/ Deere 110TLB #34
Wish I had a picture of the 18 PJ with 110 with hoe...
Tows great and 110 fits like a glove and deck has tire stops for no guess loading...
The original contractor owner does a lot of work in San Francisco where extra trailer length is a liability...
/ Deere 110TLB #35
My L48 TLB Kubota just barely fits on my 20' trailer.
If my trailer was only 18', there would be some hanging over both front and rear, with proper weight distribution likely an issue.
/ Deere 110TLB #36
It was all sold new as a package from the JD dealer.
/ Deere 110TLB #37
Interesting factoid in regards to my 2005 model 18' trailer was that the PO said that it was only used to haul a John Deere 110 TLB. So same story here, 18' trailer was set up as a new package for a 110.
/ Deere 110TLB #38
Dealers will always put the least expensive trailer in a package.
An 18' trailer is less expensive than a 20' Trailer.
/ Deere 110TLB #39
Mine doesn’t even fit the 20’ good. It’s sticking off both ends.
/ Deere 110TLB #40
Could be as before my time...
The tilt up ramps and dove tail balance nicely with the idea to stay under CDL threshold by not exceeding 10,000 pounds.
Only once was the previous owner scaled on portables on was OK
Even though plated at 9980 pounds the PJ is otherwise a 12k trailer.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
John Deere 6200 Tractor (A64047)
John Deere 6200...
SHOP PRESS (A64278)
SHOP PRESS (A64278)
Ford Pickup Truck Bed (A64556)
Ford Pickup Truck...
2022 EZ-GO ELITE...
