Sharpening wrong
/ Sharpening wrong #21
The biggest challenge when noodling is keeping the noodles flowing out of the saw. The saw will hog through an incredible amount of wood fast, and those long strings pile up directly below the saw if you try to cut the log laying on the ground. Within a few seconds the pile is plugging the saw from the outside, with no place for the noodles to go. A pain to clear the saw once it's plugged. If you can, lay 2 logs together for a table, and a 3rd log laying on top of those. That way you have plenty of room below when you cut that top log.
/ Sharpening wrong
Much better today, I came at it from the side. Seems obvious now what I was doing wrong but what’s the saying, the only stupid question is the unasked one. I was doing this several months ago correctly and like Ford850 said, the saw did plug up once in a while. The MS261 seems like a heck of a saw for its size and weight, pretty happy with it.
/ Sharpening wrong #23
Cutting against the grain as you are doing is tough on a chain and the saw. Yu need to have some good HP to do it.
A skip tooth chain will help a lot when making cuts such as this. You aren't taking as many bites of the log
/ Sharpening wrong
Just to be clear my last picture is not how I made my cut, I just have the round oriented that way to show the chips. I made the cut going through the side, the bark side. In the pic I have cut about 90% of the way through it and flipped it so the saw would not hit the dirt. Doing it the correct way is actually really fast and easy on the saw as long as the chips do not plug up. I have noticed the newer MS261 vs my older MS250 seems to have a touch more room under the cover to clear chips better.
/ Sharpening wrong #25
If he were able to stack these logs he would just put them on the splitter and be done with it. They are heavier than he want's to manhandle for fear of straining a butt muscle or smashing a foot.
/ Sharpening wrong
Smashing a foot? I’ve had steel toe boots for years but only one pair just for certain jobs at work. I started wearing them when splitting wood now. Should have been all along. I never drop anything heavy enough to break anything but just dings that hurt a little. No problem with the steel toes. I’m not sure how heavy some of these rounds were, I can lift quite a bit, but I’d guess 70 to 80 pounds. Like a lot of people I have had back trouble so why push it.
/ Sharpening wrong #27
A splitter with a hydraulic log lifter is worth it痴 weight in gold.
At 77 if I can roll it I can split it. I love my Splt fire 227 splitter,
B. John
/ Sharpening wrong #28
A splitter with a hydraulic log lifter is worth itç—´ weight in gold.
B. John
At 71, if I can't lift it (or don't want to), it can rot in the woods. :laughing:
/ Sharpening wrong
I bought a cheaper splitter. It’s only a horizontal unit, it only has a beam, no table to catch anything that is splits, no lift, and the wedge needs to be taller. It’s only something like a 17 ton but it splits about anything.
/ Sharpening wrong #31
At 58, that's exactly how I feel. I have a hydraulic log lifter on my splitter and I still won't bother messing with the monster logs for firewood. A 24" diameter Red Oak cut to 16" long weighs 260# when green. Why wrestle with it when I have so much easier stuff to deal with?
/ Sharpening wrong #32
I use my tractor, lol. I roll them into the front bucket and then lift them so I can roll them onto the splitter. Also when they split the half on the tractor side falls back into the bucket. I find that's easier than standing up my splitter into vertical mode. My splitter has the wedge that moves vs the style that pushes the log into the splitter.
/ Sharpening wrong
I do the same exact thing. The reason I noodled these is some were to big for my bucket. Some were also really stringy and when I split the the first time, they didn’t come apart and I then had to wrestle them. Big rounds are very heavy but you get a boat load of wood out of just a few of them.
/ Sharpening wrong #34
Same here. The bucket is then like a work table. I don't split as much as I used to but back then I'd put it in vertical mode and roll the big round to it. Then sit on a smaller round and get a lot of wood from one round.
Now I can't lift more than 50 lbs and any work more than 3-4 hrs will lay me up for a day or two.
Good info about the chain saw sharpening. I'd read that there are ripping chains but not recommended for hand-held saws. Sharpened at 0 degrees. I was ripping larger logs for benches and other craft projects, like turning bowls on my lathe. I bought a Farm Boss to supplement my 025.
/ Sharpening wrong #35
An old dead elm log I cut had growth ring layers in alternating angles and it would not split. First ring grew in a clockwise swirl. Second ring grew in a counter-clockwise swirl. And each ring was like that, alternating and forming almost a plywood affect. The log splitter would cut/slice through the grain but it was impossible to split, so only the height of the wedge would be cut. I had to noodle all the logs over 1' diameter, and then I could nibble them down with the splitter. My son talked me into noodling them as a test after I said I was gonna roll the whole mess in a gully and be done with it. ;) He was noodling the logs and I 'split' them when he was done. It went really well actually, and our pace was about even. We had a nice pile of hard elm when we were done, so he was right and I'm glad we noodled them.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64281)
KNOW BEFORE YOU...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2008 Volkswagen Eos Convertible (A61574)
2008 Volkswagen...
