Andrew Camarata on Youtube
Status
Not open for further replies.
/ Andrew Camarata on Youtube #121
That is where Andrew Camarata and Mike Morgan differ at least as far as their YouTube channels. Andrew shows the work and barely shows himself or anyone else & minimal talking. Mike takes a little more time to explain and will show off the family/others. I have watched both channels and as much work as Mike gets done, which I applaud, Andrew runs circles around pretty much everyone else I've ever seen.
Andrew is a 30 year old human dynamo.
Women probably don't stick around him very long.
/ Andrew Camarata on Youtube #122
Reminder: Insulting other members isn't allowed and those types of comments will be deleted. Thanks.
/ Andrew Camarata on Youtube #126
I often find a YouTube presenter who I respect and trust UNTIL HE PICKS UP A SPONSOR and there's a pitch of the sponsor's product with every video. Hopefully, Andrew will never get a sponsor.
/ Andrew Camarata on Youtube #127
What a D-bag... I guess the truth hurts? Let's get back to the real Youtube star, Andrew... muskieken, Good interview, I heard that a while back....
/ Andrew Camarata on Youtube #128
Always amazes me when someone takes a power washer to a powered implement and in particular, the engine.
/ Andrew Camarata on Youtube #129
What's amazing about it? Don't you ever clean your equipment? :confused:
I pressure wash all my equipment, including tractors, lawn mowers and golf carts when they need cleaning. Some of us don't have climate controlled parking. :confused2:
/ Andrew Camarata on Youtube #130
Do it all the time too. You have to excercise common sense. Nothing like a squeeky clean engine.
I have more questions about cleaning greasy bearings actually.
/ Andrew Camarata on Youtube #131
So do I. In fact all my farm tractor engines. my pickup truck engine. the lawnmower engines are all always clean and dirt free. Transmissions too. I hate handling grimy stuff. Besides, if you have an oil leak it's easy to see. I just don't use a pencil point nozzle, always a wide fan spray tip and I use a good cleaner / degreaser like Zep. I clean my greasy bearings in my hot bath ultrasonic cleaner and I use Berryman's chem tool and then pressure repack with a double cone bearing repacker.
/ Andrew Camarata on Youtube #132
If they are behind seals or just a bushing, I spray degreaser around it and use a plastic bristle brush to scrub. I use the purple stuff with the minimum water. (I do this before pressure washing) After washing: Re-grease to make sure no water got behind the seal or into the bushing.
If you're talking about washing the grease out of a free bearing, I use a solvent (naphtha usually) and an old paint brush to work the old grease out. Blow dry and make sure no debris is left behind. Pack with grease and reinstall.
/ Andrew Camarata on Youtube #133
I'm concerned with getting water in the bearings.
If cleaning end of season, one should clean the bearings, apply grease and run it again. WIth a lot of equipment, who can do that? Usually a big rush to get everything cleaned and inside. Sometimes in a snow storm!
/ Andrew Camarata on Youtube #134
Youtube is no different than any other site, you can watch what you want and skip what you don't want. No one promised anything on the internet to ever be true, (you can check that on Facebook and at least one other forum if you don't believe me). Andrew is informative and entertaining, to those who follow him. I like his channel, look forward to the repairs.
/ Andrew Camarata on Youtube #135
I like Andrews channel. I don’t think his latest video is his best work though...I don’t know know how he didn’t break the bell housing on his D4.
/ Andrew Camarata on Youtube #136
Just to be clear. Is Camarata a member here? I don't understand the warning (From the management) about insulting another member, BUT, if a member did have a youtube channel, does that mean we can't say bad stuff about it here?
/ Andrew Camarata on Youtube #137
Two or three people here tend to constantly throw some snarky comments towards Mike and his family from Outdoors with the Morgans, which is a member here. The management did delete those posts on this thread though.
Snarky to say the least. Some of those comments are actually way over board.
/ Andrew Camarata on Youtube #138
Actually, having read tons of comments on Bit chute lately, I can appreciate the general civility here.
/ Andrew Camarata on Youtube #139
I agree. That was indeed a hard video to watch. He would either crack the bellhousing, or have pieces from the starter nose fall around the flywheel. Could get messy really fast.
In the end, I'm sure the old starter would just need a good cleaning, new brushes, good lubrification and was good to go. I've done it several times.
/ Andrew Camarata on Youtube #140
Yes, while watching the video, I said to myself "ohhhh, no".
Status
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
2011 FORD F-450 (A59908)
2011 FORD F-450...
207278 (A52708)
207278 (A52708)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2018 RoGator 1100C (A61307)
2018 RoGator 1100C...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2023 GMC 1500...
