Weight of water
/ Weight of water #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I have a 2" PVC pipe with an inside diam of 2.067 that is 100 feet long.
Also within that same pipe is a second sealed 1" pipe that has an outside diam of 1.315 same length.
How heavy will the water be?
My intention is to push that column of water from the bottom to the top and I need to know this answer so I can plan the rest of the pump accordingly.
Please dazzle me with how you came up with the answer. Thank-you
/ Weight of water #2
16.65 pounds
Larger pipe area is inside diameter squared times pi divide by 4 subtract the outside diameter squared times pi divide by 4
Divide that number by 144to convert to square feet multiple by 100 to get cubic feet multiple by 62.4 pcf for water to get answer
Done on cheap small calculator so I probably have fat finger mistake in final answer
/ Weight of water #3
Fat finger or not................lI'm impressed.
Cheers,
Mike
/ Weight of water #4
The weight of water will be ~8.34 pounds per gallon.
The water will be the same weight if it's in your hand, a glass or in a pipe. :rolleyes:
/ Weight of water #5
If it’s vertical at STP you will need at least 43.3 or more psi of air pressure to move it all in one slug.
/ Weight of water #6
Is the water only in the annular space between the two pipes, ie, inside the big pipe but not inside the small pipe? If so, I calculate 86.56 lb of water in that annular space.
Weight = [area, ft^2]*[length, ft]*[density, lb/ft^3] = [(pi/4)*(2.067^2 - 1.315^2)/144] * [100] * [62.4] = 86.56 lb
Now, that said, if you want to size a pump, the weight isn't important, the pressure at the bottom of the water column is. That would be 6240 PSF or 43.3 PSI.
/ Weight of water #7
The 86 # is what I get, too, and agree on the 43.3 psi.
/ Weight of water #8
That 43.3 psi is only if the pipe is vertical. If he's running up a slope it will be less. The formula is 0.433 * elevation change. Depending on the rate of flow (gallons per minute) there will also be pressure loss due to friction in the pipe.
/ Weight of water #9
Just a simple quick way to roughly figure out PSI is take the height and cut it in half. It will give you a rough PSI not taking into account friction loss. So a 100 ft rise would be 50 PSI.
/ Weight of water #10
Good tip. Easy to remember. Just dont forget thas its rough. ;)
/ Weight of water #11
A train leaves Buffalo Eastbound at 40 mph at noon while another leaves Albany Westbound at 50 mph at 1:00 p.m. When and where will they meet ?
/ Weight of water #12
What others have said 43.3 PSI pressure. Plus what is the pumping rate? The faster the greater the friction loss.
You could have a 12" diameter pipe 100 ft tall. The pressure on the bottom would still be 43.3 PSI. But friction loss would be much less than a 1" diameter pipe. W. Jones
/ Weight of water #13
In the early afternoon (sometime between noon & 1 pm) and between Buffalo and Albany.
/ Weight of water #14
Nah, they wont meet. That line is double tracked so they will only pass each other :D :D :D
/ Weight of water #16
The weight of the water (pipe diameter) doesn't matter. The rise determines the minimum pressure needed if you want the water to reach the top of the pipe. More than minimum pressure will make water flow out of the top of the pipe.
Bruce
/ Weight of water
We have 16.65 pds, 8.34 pds and 86.56 pds with #7 agreeing and a train that is leaving at Albany and Buffalo, now I dont feel so bad. :thumbsup:
/ Weight of water
Bruce
Weight of the water has to be addressed as I am considering a simple/custom backflow preventer.
Id just like to know the weight of the water as asked but I understand its not an easy question. Thanks
/ Weight of water #19
Is this part of your new septic system plan?
As others have said the pressure depends on the elevation.
/ Weight of water
No, I have a second cased hole in the ground that was given up on and Id like to see if I can get any type of recovery rate from it, I dont want to invest alot of money with buying a pump until I know that it has a recovery rate period so I am going to build a hand operated deep well pump.
2025 Miscellaneous Mini Excavator Attachments (A61572)
2025 Miscellaneous...
LOT LOCATIONS (A59914)
UNUSED SDLANCH HYD DUMPER (A64280)
UNUSED SDLANCH HYD...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
(1) UNUSED 11.2-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 11.2-24...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
