Curtis cab latches
/ Curtis cab latches #21
Nobody said they were perfect. What was your first choice and why did that one become no choice at all?
The obvious observation from pictures only was that the latches needed adjustment, I do offer a double your money back guarantee on any bad advise I give.
/ Curtis cab latches #22
They are good cabs I think it just not adjusted correct see post #12 looks like the bracket is hitting the striker bolt....The dealer should make it correct they installed it.....
I'm afraid this got off topic for a bit. I have a problem, I'm just asking if anyone else has experienced this, and how it was resolved.
Bottom line, the latches don't work. The instructions only say, "adjust them". I've loosened the adjustment bolts. I've pushed them through the full travel of their adjustment, eventually I got one to work, sorta.
This is the lever all the way down.
This is the lever all the way up.
I have no idea which way is "open". The arm stays around the pin, period.
This is a roof latch, I've moved it through the full range of adjustment, but it can't be moved.
Can the latches themselves be assembled wrong? If something is wrong, could the act of tightening the adjusting/mounting bolts prevent them from moving? Unlikely, as I can't move the lever even with it hanging loose.
Push come to shove, I can simply unscrew the pin the latch locks onto. Less than handy, but in reality, I only want to remove the rear panel for the heat of summer, replace it for the cold of winter. That's removing and reinstalling the pins once (probably twice on the roof so it's not loose to bounce) a year. But I'd really prefer them to simply work.
I'm trying to work this out now, so it can be done when it needs to be done, rather than spend half the summer doing it.
/ Curtis cab latches #25
If you unscrew the striker and unbolt the latch completely from the panel you may be able to solve your problem when you can examine the latch from all angles from a more comfortable position. Hopefully removing one will allow you to find a solution for all.
Agreed.
The cold of the next few days will prevent this from happening, so it will take me a few days to update.
Curtis might get back with me too. It all takes time, which is why I'm asking now when it doesn't matter if I can open up or not. I want to be able to when I do need to open up.
Thanks.
/ Curtis cab latches #28
It looks so easy in the video.
Yes it does........
Seen that video, and yes it looks easy. Mine DO NOT move. Don't know what to say other than those work, mine don't, hence my problem.
In the video, there are also handles he hooks his fingers through, which I don't have.
The installation/owners manual is vague with little information.
Trust me, I've searched the internet at length, watched dozens of videos, nothing addresses my issue.
/ Curtis cab latches #31
If you lived closer I would come over and look at it . Maybe call the dealer and see what they will do or have somebody else look at it / and help you ...
/ Curtis cab latches #32
The vid has the latches pre-thrown. I think you need more leverage. Maybe pull off the rubber covers and use channel locks. I'd also call the dealer and have them adjust the levers. I suspect they are too tight. If you have limited strength, perhaps lever extensions are in order. Maybe one "wrench" the fits over the handles.
Due to having to remove snow, down with an ailment, and it just being to cold..... I haven't even looked at lately, but will take all suggestions to heart.
Thanks.
Ok, see where the pin screws into the frame? The brass part is a rivot nut, the pin screws directly into it, the washer on it does NOT belong there. Why he put it there, and one on all 4 pins is beyond me, but taking it off, sure helped.
While it still doesn't work like the ones in the video, they DO work now. Maybe further adjustment will help that, maybe it's just my limited range of motion, or maybe that's as good as it will get.
/ Curtis cab latches #35
I can see why that would make it almost impossible to open as you would be binding the latch against its own frame.
Aaron Z
/ Curtis cab latches #36
Good, you found the problem. Not having young eyes and flexible joints makes extra work for almost everything.
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
Caterpillar Vibratory Compactor Parts and Service Manuals (A63117)
Caterpillar...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
3096 (A63117)
3096 (A63117)
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2014 FREIGHTLINER COLUMBIA GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2014 FREIGHTLINER...
