Deere 110TLB
/ Deere 110TLB #2
Search and read the threads and warnings on them here. Sounds high for a high hour machine. From what I've read more than a couple of them developed cracks in the bell housings. They are built on a 4000 series CUT frame so limited in capability.
A 110 was on my short list when I started searching but I'm glad I went with a full size backhoe and a separate tractor for other uses.
/ Deere 110TLB #3
They have a bell housing problem of cracking and $$ to fix..
/ Deere 110TLB #4
Shop around and you should be able to find a decent Deere or other brand backhoe in the low 20s.
Also read and search some threads over here for info on full size hoes. Tractor/Loader/Backhoes | Heavy Equipment Forums
And for crying out loud when multiple people tell you to stay away from a brand for one reason or another DON'T turn right around and buy one anyways. I have read threads asking for advice on two different forums where people ended up buying the exact brand or model they were warned not to buy. Total waste of everyone's time that tried to help them.
/ Deere 110TLB #6
You could get a full size backhoe for 20k, But I don't now what your trying to do...
/ Deere 110TLB #8
Looking at a 110TLB, 5500 hours, 4-1 bucket and thumb, low 20's.
Anyone else have experience with a high hour machine?
Mine has been a good worker for what I do with it which is 菟roperty clean up around the farm and some rentals properties in town. I can trailer it easily with a 3/4 ton truck. The thumb is extremely handy. I also have a JD auger which I use on the backhoe to set corner posts. That has been great.
Anything can be broke if you aren稚 careful. The 110 is not a 吐ull sized hoe but it can be very useful if you use it within its limitations. Like anything else.
No one machine will do everything.
I am looking at a CTL with a brush cutter for sometime in 2021. I may want to expand beyond just what I do for myself. The dealer痴 eyes really lit up when I told him I had the 110 although I never mentioned trading it and even told him I wasn稚 planning to do that. He sure wanted to look at it and see what 塗e could do?
I wouldn稚 look too favorably on a 110 with 5500 hours for $20k. Sounds like way too much $ for that many hours.
I wouldn稚 tell anyone to rule out a clean, low hour 110 but that shouldn稚 be the only thing you consider either.
CAT has their rental system down pat. If you have some work you are ready to do might try renting a couple different things and then buying. Kubota also has perfected a pretty good rental system. JD has some catching up to do in getting their system down pat. But they will catch up soon.
Locations
Good luck with what you decide to do,
/ Deere 110TLB #9
Thanks all, I'm going to take a pass on it.
Good choice!
I thought I wanted a JD110 TLB, but luckily, found (CL) a nearly perfect, (2006) 251 hour, orig. owner, Kubota L48 TLB.
Kubota TLB's have zero history of cracked cases.
50% more than your price range of "low 20's" though.
/ Deere 110TLB #10
My 110 TLB has been very dependable... the hoe is awesome for the size.
I did have one senor go out... thankfully it was a $50 part... but I did have a scare when I called dealer and said it could be transmission.
Its at the limit for what I can tow so bigger wouldn't have worked.
/ Deere 110TLB #11
I can certainly understand that your JD110 TLB is great.
It is quite likely that most of them are great.
The potential for a case crack "scare" though, is the very reason that I could just not bring myself to do it.
Whatever the odds.....there is that somewhat less than stellar JD110 history.
/ Deere 110TLB #12
Somewhere there was a thread where the owner replicated a bell housing by hogging out a billit...
Seems most tractors have something... I know my BX had two... the belly plastic cooling fan and air cleaner bracket...
Extended operation with broken fan leads to more expensive problems.
/ Deere 110TLB #13
I've had a 110 TLB for about a year. They seem to bring between 30-35K around here no matter what. Did see one sell in the high 30's a few years ago due to low hours but didn't have any Aux hydraulics at all (3rd function/7th function/3 SCV)
I like the tractor, no issues with cracked bell housing here, just need to ensure the loader mast bolts stay torqued. That said my tractor hasn't been abused in the loader area and was never a rental. It was used as a PTO tractor for bush hogging, box scraping and Harley Raking most of its life. The model ran for 10 years with one main change after the first year or two. Not many compact tractors, or any that I can think of have the extra 3rd hydraulic pump that is dedicated to run the loader & backhoe. I believe the other two pumps are dedicated to the hydrostat and steering. My favorite feature about it is the low profile sloped hood. Makes using pallet forks a breeze due perfect visibility, or any front tool for that matter.
/ Deere 110TLB #14
Yep... all attributes.
/ Deere 110TLB
If all I needed was a hoe, I'd be looking to pick up a mini-ex. My other tractor does not have a bucket, so this 110 with a thumb and 4-1 bucket and abilty to utilize implements with a 3pt. seemed to fit the bill
/ Deere 110TLB #16
Correct!
A mini excavator is for digging, and lifting things.
A TLB is for those things also, but also for grappling, and moving dirt, relatively quickly from place to place..... beyond just a short mini-ex reach.
/ Deere 110TLB #17
A contractor bought a 110 about the same time I bought mine. He said he was going to use it primarily with a box blade grading day in and day out. Said the hoe would be secondary and not used much.
/ Deere 110TLB #19
Look for a trailer at the same time.
2017 Chevrolet Silverado 1500 Pickup Truck (A64194)
2017 Chevrolet...
2023 BOBCAT L28 ARTICULATED LOADER (A65053)
2023 BOBCAT L28...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
