KennyG
Super Member
I'd say that their cleaning directions are spot on - ours catches a lot of dirt and I was cautioned by a friend who is in HVAC that the one we have at least, passes less air than a typical, normal furnace filter, so you really don't want to let them get clogged up.
I suppose lack of airflow could cause the heat exchanger to overheat.
It's really more of a problem with A/C. Low air flow will cause the coil to freeze. I run high efficiency filters (the corregated filter material) in the winter but cheap fiberglass ones in the summer to avoid freeze up. Of course, it may be my systems isn't quite up to specs.
