Now I Need A Grapple. . .
/ Now I Need A Grapple. . . #41
Well, that's all you'll need... Except for the grapple of course:D
Not knowing which connectors they installed on the hoses on your tractor. You might want to discuss the connectors you have when you call EA, so they can install the correct quick couplers that will match up to yours.
I didn't discuss this, and had to take off the connectors shipped on the grapple, and buy some that worked with what was installed on my tractor
Aren't most manufacturers using flat face couplers?
/ Now I Need A Grapple. . . #43
Like everything else, it depends on how much use you expect to have for a grapple.
I love EA products, but the EA 60" Wicked root grapple is $2650.
In my case, the bottom teeth on that grapple were not a design I felt would work well for ripping vines out of trees/bushes.
In addition, I will only use a grapple occasionally, since I have EA forks, a bucket, ratchet rake, and a very capable 11' dig hoe.
I bought a 60" root grapple from Mid State Attachments (Denton NC) for $1152.
Certainly not nearly as precisely made as EA stuff, but still, seemingly very capable.
It does not have any zerk fittings at the wear points, but I will remedy that, for just a very few additional $.
$1152 v/s $2650 is a $1502 difference, and as above, the EA tooth design was not acceptable for my use anyway.
The EA grapple weighs 400#, while my grapple weighs 500#.
Not a big difference for my Kubota L48TLB.
BTW: Mid State Attachments shipped me the wrong grapple first.
No problem!
They paid return shipping, and immediately shipped the correct model.
GREAT folks to deal with!
Maybe it is in the North Carolina water?
I get all that. I researched many grapples. I bought the EA because I thought it was the best grapple for the money. And, would hold up to the abuse my CXZ could throw at it.
I did have an issue. One call to Travis and he e mailed me a shipping label to ship the grapple back.
It's been solid since. I cleared an entire 10 acre pasture with this grapple. digging up rocks and back dragging the soil
I'm a very happy EA wicked customer
Some love a diesel truck, and pay xtra for it. I did
Some don't and wouldn't..
I completely understand that
/ Now I Need A Grapple. . . #44
I get it!
I have two EA attachments, and they are GREAT!
If EA had a root grapple design that met my needs, I probably would have bought it.
/ Now I Need A Grapple. . . #45
Mid state shows their 60'' E series for ''lower HP machines'' @1499.99 plus shipping
Is this the one you purchased ?
I would like for the lower tines on the EA to be a little longer. But, it works well like it is.
If doing heavy digging in hard dirt / rocks ,The longer the tines the better chance of bending them
/ Now I Need A Grapple. . . #46
YES, That IS the model I purchased from Mid State.
$900 + 252 shipping ...last month.
I also saw that MS price listed on the internet.
Instead, a direct call to "Connie" at Mid State, got me the $900 price.
Calling any small manufacturer directly, will sometimes get a much better price.
I am replacing all 6 pins with very slightly larger brass pins and zerks.
The factory pins were VERY (1/8") sloppy, and steel on steel, with no zerks!
It was not a surprise. For the price I got exactly what I expected.
The replacement brass pins, nuts, etc. cost me less than $60.
Why brass? Much easier to deep drill for grease passages, and if there is any wear, it will be the brass pins, instead of the A-36 steel fabricated grapple parts, or the cylinder end fittings.
The longer tines are EXACTLY what I wanted!
I would need to work at it to bend them.
There is not a "rock" larger than a dime within 5 miles of here.
Pure natural sand.
Well drillers NEVER hit any rocks!
/ Now I Need A Grapple. . . #48
Okey Doke. . . I called EA and talked to Travis. Really nice guy and very helpful. Learned a lot from a short conversation. Not knowing what I don't know, I kinda focused on the Wicked Root Grapple with the dual lids and long bottom tines, but after talking to Travis, I believe I am leaning more toward the Wicked Root RAKE Grapple. Grabbing brush, logs and pulling vines out of trees seem to be in the wheelhouse of the first one mentioned.
I like the EA a lot, but as Fried1765 and others mention, there are other grapples out there that will do the job and at an easier price point.
Shipping would be $35 to get it to my pick-up point. But 10 Weeks Out! ! ! I'd love to have a business that was that busy.
Unless you are pressed for time, the EA 60" wicked grapple is a perfect fit for the MX series and what I own. I do not feel that I'd get better productivity from a dual lid grapple. In the year I've had it, I've moved lots of logs right at the weight limit of the loader. About 2000 lbs. No problem. I have moved the occasional boulder too. Mostly I use it for brush clearing and gathering. In a week or two, I'm going to use it to serve logs to a saw mill. That will be fun! So far, no damage if you don't count the paint. I also use it to tend burn piles. The grapple and tractor look like Mongo lighting his cigar during the beans scene of blazing saddles. :) I just reach in there and stir things around. Everything comes out sooty. The tractor gets a bath later. The grapple, not so much...
The only negative thing I'll say, is that EA should offer a hose management solution. I had to go to Ken's bolt-on hooks to get a springy thing to support the hoses. i'd rather do one-stop shopping. Of course, while you are over at Kens bolt-on hooks, order some bolt-on hooks for your loader bucket. :)
Yep, I am 99% going with the EA Wicked Root Grapple. Moved on from the dual lid after talking to the EA folks. I will be using mostly for the things you described.
/ Now I Need A Grapple. . . #50
I solved the hose management thing with a bungee cord tye wrapped one end in the center of the hose bundle going to the grapple. Other end hooks on to a fitting up on the loader arm. Cost is about a dollar, and take less than a second to attach the end on the loader and the cord will last several years. When it dies, spend the dollar and get you another one. Simple, Cheap, easy to deploy and works very well to keep your hoses from hanging up on things etc. Highly recommended by me. :)
/ Now I Need A Grapple. . . #51
I did that for a long while. The purpose made springy thing does a better job.
/ Now I Need A Grapple. . . #52
Boy Howdy I am really finding out things I didn't know, I didn't know. Here are the connections they put on. I am assuming these are the correct fittings.
Before you order try to figure out which style and size connections you have and request compatible connections be installed on the grapple. Alternately ask them to leave them off and apply a credit so you can buy your own fittings local. Differences in Quick Couplers Hydraulic Valves - Dynamics You can flip the connectors to either hose to change which button opens or closes to meet your preference.
I assume your tractor has the skid steer quick connect but make sure of that when ordering.
I have a MTL 60" RK5 grapple with the John Deere quick connect I am fairly satisfied with for the price. Mine arrived in 3 days to my door. They charged an additional $60 over free to bring it right to my property. IF their tooth designs look like they would meet your needs I believe them to be a great value for an American made product. Tractor Attachments — MTL Attachments
I have read some posts by people dissatisfied with their customer support. I have inquired about a smaller single lid root style and they never replied. They probably don't make it any more and didn't want to waste their time or maybe they just don't monitor their online messages. I didn't try calling them.
/ Now I Need A Grapple. . . #53
I have a MTL 60" RK5 grapple with the John Deere quick connect I am fairly satisfied with for the price. Mine arrived in 3 days to my door. They charged an additional $60 over free to bring it right to my property. IF their tooth designs look like they would meet your needs I believe them to be a great value for an American made product. Tractor Attachments MTL Attachments
MTL has a VERY poor customer service feedback!
I would suggest Mid State Attachments, in Denton, NC.
They have attachments priced similarly to MTL, and the Mid State people are great folks to work with.
They have been in business for 20+ years, and they do have a website, with their various models listed.
Their phone number is: 1-866-811-5319.
If you call,( Connie) and ask, you will likely get a MUCH better price than their internet listed price.
I did!
/ Now I Need A Grapple. . . #55
My MTL RK5 has a solid back and it has some advantages.
I just tried to offer a suggestion on fittings and an objective view of the MTL. Had i needed any service from them and was met with some of the stories I've read I would probably DIS them too.
If customer service is worth twice the price and a 10 week wait by all means go for what you feel comfortable with. Everyone has different priorities.
/ Now I Need A Grapple. . . #56
/ Now I Need A Grapple. . . #57
If and when I need a grapple I run to the wife's work and pick one up.............. 0828160917-00.jpg
/ Now I Need A Grapple. . . #58
/ Now I Need A Grapple. . . #59
I have run my EA 55 Wicked Root Rake Grapple most of the time on my little 34hp tractor. I think I've only had the bucket back on once, I think. The grapple is so darned handy. I've cleared off all the brush and small coastal oaks on my 5 acres, and used the grapple to hold up felled trees so I can section them without bending, which my back is happy about. Load the brush in my trailer and pack it down with the grapple - had to buy a hydraulic dump trailer, cuz it packed it in so tight I had to cut it out of the landscape trailer I had. Now I dump a big cube and drive away. I throw a chain through it and pick up machinery, trailers, whatever. Haven't used my shop crane since I got the grapple.
Travis at EA is a gem. I got mine in April, 2018. I see they have beefed up the lower tines, but mine have worked fine. I'm STILL a happy customer!
https://www.tractorbynet.com/forums...ractors-15.html?highlight=Teachu2#post5051152
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
2016 Sky Jack SJ8831RT 31ft 4x4 Rough Terrain Scissor Lift (A61572)
2016 Sky Jack...
Case IH Onland 3pt 6 Bottom Flip Plow (A64119)
Case IH Onland 3pt...
Caterpillar 214-224 Wheel Type Excavator Service and Parts Manuals (A63117)
Caterpillar...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
