Harbor Freight FCAW welder
/ Harbor Freight FCAW welder #21
Make sure you have job ready to weld up day you get de machine home, and I mean big job.
Unbox, plug in and test machine to de max right den and dere.
Run it like stolen car for few days.
Makes you happy and fills all yer needs keep it. Don't, take it back, no questions asked.
/ Harbor Freight FCAW welder #22
I think welding is a lot like guns. Ask about a good deer rifle and there are some that will insist you need some version of a magnum with at least a 20x scope.
I needed to fix my gate and the only generator I have is a Honda 2,000i. I asked about using my HF Titanium 125 FCAW welder with that generator. I don't think I got any responses that it would work.
I thought "No harm in trying" so did a test run. I couldn't pound the pieces apart with a hammer. So, off to the gate I went and made the needed repairs.
Yeah, I'd prefer to weld with MIG and shielding gas but the would require setting up wind blocks around that gate. Flux core was easy.
Needed to weld a trailer winch onto the skinning pole recently. Quick and easy.
For outdoor "farm type" repairs, I'm very happy with that machine.
/ Harbor Freight FCAW welder #23
Trick to runnin little weldin machine from generator.
Pretty obvious if you ever watch generator and use voltmeter.
Load hits generator it bogs second or 2. Dat OK wid lightbulb but welder need max power same time generator is bogged.
Trick, load generator wid something big enough to get past bog and back to speed. Den welder see full voltage at start of weld.
Welding & guns, kinda sorta maybe. Talk to gun shop owner he tell you how he makes money selling new gun and taking back for part of money. Owned by little old lady who only used it to keep congregation awake when preacher was boring.
/ Harbor Freight FCAW welder #24
I think my generator has an "economy" switch. That switch lets it run at lower RPM until needed. Flip the switch off and it runs at wide open throttle.
For the welding project, I ran it with that switch in the off position. I don't recall it bogging down at startup but it is a valid concern.
I had received so much advice that I needed a bigger generator that I almost purchased one but thought "Give it a try". **** if it didn't work out just fine.
/ Harbor Freight FCAW welder #25
Harbor Freight had their Titanium 125 FCAW DC inverter welder on sale for $159 so I decided to buy it. I dont need to weld thick stuff, I have stick rod for that, so the 125 works well for me. I just got thru welding up some shelf brackets I fabbed out of 3/32" thick sheet metal. The little machine worked great. So far it hasn't kicked out on overheating. I think I am going to like it but it does throw off a lot of buckshot.
I have had an Airco MIG 100 for 30 years that was given to me by a LWS and I never used it due mainly to not wanting to buy another gas bottle. I may invest some more money in a 75/25 bottle and try it out later and try it out since I think if would weld smoother than the FCAW. I never really thought about what I could use it for since I have the 250 amp AC/DC Miller stick machine
Like Century FC90, the titanium 125 has good reviews. I was looking at both, but went with the FC90.
But I just couldn't get down with fcaw, I got a mental block to it or something. Personally, I much prefer stick.
/ Harbor Freight FCAW welder #26
I have the same generator, and I just bought a FCAW last week from my farm store. It has 2 power settings, high & low. Numerically that is 60 and 90 amps.
What amperage were you using to fix your gate?
It would be good to know that 60 amp is do-able and even better if the 90 amp setting will work for short weld times.
/ Harbor Freight FCAW welder #27
Which welder did you get and from what farm store? Are you happy with it's performance?
/ Harbor Freight FCAW welder #28
I don't recall the settings, sorry. My machine (the HF Titanium 125) has two dials. One is letters and one is numbers. I checked the chart inside the lid and did some test welds. I don't know how to convert it to amps.
/ Harbor Freight FCAW welder #29
During a power outage I was trying to start a refrigerator with a 1.5KW generator, not enough omph. By holding the governor open and letting the engine overspeed for a few seconds, it would store enough energy in the flywheel to start the refrigerator motor that would then run fine.
/ Harbor Freight FCAW welder #30
Replacement frigerators & freezer sales go way up about 2 weeks after power failure. Most get replaced in houses wid automatic generators dat come on line fast to replace power company.
Cooling compressor needs time after shutoff to bleed down head pressure or it can self destruct starting
Sump pumps are pure he!! to start too
Newer oil burner wid electronic control very sensitive to power frequency. Under 58 and over 62hz will throw to shutdown for flame failure.
1012 (A61165)
1012 (A61165)
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
