Snow PTO Switch Help and General Part Buying
/ PTO Switch Help and General Part Buying #1
undercoverpoe
Member
Southern New England
JD425
Well Googling “John Deere 425 PTO Switch” didn’t do me any good other than waste $20. IMG_5159.jpg
Looks pretty close here right?
Note the bottom of my old switch has two NOT close together. The new switch has two close together.
So I guess this isn’t the right switch for my Early 425? I wish there was a part supplier that I can actually use my serial number to see if I’m buying the right part number. Or even find a parts blue up where I can actually find the part I need. Where the F**K is the pto switch in any diagram? Any help would be appreciated
Bottom of old switch for your reference to help identify it vs the one I bought
/ PTO Switch Help and General Part Buying #6
Hi Undercover. In June of 2016 I replaced the pto switch on my 925m ztr. The geometry of the pins is the same as your old switch. The part# from my Deere dealer was TCA21027. I’m sure because I kept the old switch as a spare since replacement did not fix my issue back then .
Good luck.
Frank
/ PTO Switch Help and General Part Buying #7
/ PTO Switch Help and General Part Buying #8
/ PTO Switch Help and General Part Buying #9
It's NOT same switch for above and below serial number 70,000
LVA21437 & A-B1EM48 is for 70,000 and below.
AM21438 is for 70,001 and above.
/ PTO Switch Help and General Part Buying #10
The P/N you bought is for serial numbers 70,001 and above. You need P/N LVA21437 OR A-B1EM48
Trimble EZ Guide 500 Monitor (A63117)
Trimble EZ Guide...
86 (A63290)
86 (A63290)
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
2024 GMC Yukon Denali 4x4 SUV (A61574)
2024 GMC Yukon...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
