Snow Attachments Quick Attach hydraulic angle snow plow
/ Quick Attach hydraulic angle snow plow #1
KeithT
West Virginia
Kioti CK3510HST SE
Good morning, long time member on this site. I don稚 get on it enough though obviously. While doing some casual reading I had an epiphany.
Here in the mountains of West Virginia like a lot of areas we haven稚 had much snow for a couple years. I tackled a 17 inch snowfall last week with my rear mounted snowblower that I haven稚 used in 5+ years. Worked very well. The plow I have on my Kawasaki mule wouldn稚 even touch it.
I upgraded my tractor a couple years ago to a Kioti 3510 HSE. I did a quick little search and saw that land pride and extreme attachments both make hydraulic angle quick attach snow plows.
Just curious what folks with experience with these attachments might recommend? I have a quarter mile long driveway with one section that is a 12% incline.
Thank you!
/ Quick Attach hydraulic angle snow plow #2
Not impressed - snow pusher may be better. I use my 3pt blade, seems to work better
Problem with the factory built ones ;no plow float.All right for paved surfaces ,not so much for gravel.All truck plows have chain float.
I see the advantage of the floating plow set up. I always just assumed I would use the float on the loader. But I see this often puts too much weight on the plow itself.
Maybe I am better off investing in a hydraulic angle plow for my mule. It is just The one or two times a year we get a heavy wet snow, I have to use the rear snowblower for the tractor, I was hoping a plow would save me from having to do this as often.
/ Quick Attach hydraulic angle snow plow #5
My tractor has a 8' truck plow on the FEL,just put a plow on my ATV for the light snows;they push like crazy.
Yes, I agree. Overall I am happy plowing with my Mule. It is much faster compared to a tractor as well for my long paved drive.
/ Quick Attach hydraulic angle snow plow #9
Thanks for finding this builder. Interesting solution.
/ Quick Attach hydraulic angle snow plow #10
Almost 3 years ago I bought a front mount, hydraulic angle plow and quickly discovered it did not work well on my long, winding, up and down gravel driveway. So I came up with a temporary solution to make it float. I figured if the temp solution didn't work I could return the plow to it's original state and sell it. However the temporary solution worked better than expected and I am still using it today.
I agree with the person that said fixed plows work well on relatively even / flat surfaces but not on undulating surfaces. My driveway is one mile long, narrow, steep and gravel with a lot of twists and turns plus it rolls up and down. Using the plow in a fixed position was scary and did not work well, no matter what I tried or how hard I focused on keeping it at the right height. After adding the float, it works very well.
The plow I have is an HLA 96" plow with hydraulic angle and rotary oscillation (this allows it to follow the cross slope on the driveway). With my solution I also get the benefit of having a fixed plow by simply tilting the fel forward, which forces the rear mounting plate to contact the plow mounting plate. When I do this I can easily lift the front of the tractor off the ground, if I desire, without causing damage to the plow system. The disadvantage to this mounting system is that it moves the plow slightly further forward. I'm guessing about 6".
/ Quick Attach hydraulic angle snow plow #11
Mr. Hilbilly, your plow seems somewhat unique with the rotary connection.
It would be good to put a post over in the long running "Show Your Snow Equipment" thread.
It seems like a solid, efficient set-up.
/ Quick Attach hydraulic angle snow plow #12
Mind U my ride is a CUT, but I found that U need to have a heavy tractor to push an angled plow.
With a quantity of snow up front pushing at an angle I often found my CUT being shoved in the opposite direction.
So much so that I scrapped some rims from crabbing.
I did prior operate a plow truck and no way can a tractor plow and curl snow the same way.
My solution was to dedicate my tractor plow into a straight 'pusher' with one wing (ear?), one as then I have minimum spill over and always where I can control it.
Mind U I only use the pusher for minor snow events as the blower gets the white stuff well out of the way.
(We get a lot of snow here in Quebec.)
Comment:
The further the blade is from the front wheels, the more side pushing you'll get.
Short coupled is best.
/ Quick Attach hydraulic angle snow plow #13
My suggestions would be to build your own, if you have that capability. Mine is fabricated from an Exmark zero turn plow. It's frame mounted, chain supported for float and, when angled, is only about 3 inches from the front tire. That minimizes side thrust and also minimizes overall length of the machine. Both good things.
1995 Kenworth W900 Studio Sleeper (A62613)
1995 Kenworth W900...
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
iDrive TDS-2010H...
UNUSED WOLVERINE QUICK COUPLER 3 (A64281)
UNUSED WOLVERINE...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
