Snowblower Which snow blower
/ Which snow blower #11
Guess l'll be looking for a blade as im not putting a 3 point on the rear.
Do you need a snow blower? I checked a couple of weather sites that indicated Norfolk, VA averages 5" to 8" snow per year. While a greater amount is possible in a singe storm, such a storm may be less frequent than once a decade. With a blade you may need the 3 point hitch to carry a counterweight.
/ Which snow blower #12
Mid pto is listed as an option on tractordata.com
Likely mid pto can be added but not cheap.
Most efficient way to get power to a front mounted blower.
Dave M7040
/ Which snow blower #13
How deep are your pockets? Erskine makes a rear pto powered front blower. Pricey though. I did a fel mount blower, powered by the rear pto, lots of work, still working out the bugs. I'll be 70 in May, loving the forward action. Still have a rear blade to drag from garage doors.
/ Which snow blower
Dave, my manual shows a mid for this model is not an option. Also maybe l better update my address as l retired last yr and moved from Norfolk Va to central Mo. lol
I love a front mount but at 6.7gpm idk. Funny thing is l see pics of SMALL masseys with front snow blowers. What gives...
/ Which snow blower
metalbender. Toooo much routing all that for a rear to front.
/ Which snow blower
I usually just leave the box blade on. It's over 700lbs...
/ Which snow blower #17
I'm in my seventh decade and the NH T1030 with rear blower & FEL has proven ideal. The open seat can be a little chilly but the machine just cleaned up a 30+ inch snowfall in hours.
/ Which snow blower #18
They are all mid mount 2 stage snow blowers.
You could purchase the P680 snow blower and mount the entire snow blower
on your loader with a SSQA plate using a ROTAX 23 horsepower go cart engine
to power it and have enough torque to clear snow.
/ Which snow blower #19
Have you considered a Rear Pull Snowblower? Much less looking back. I love mine.
/ Which snow blower #20
If drifting isn't a problem, that pull type would be great, in addition to a front blade. Two passes with the blade to bring the snow to the middle, final pass with the tractor straddling the snow, blow with a smile on, looking forward.
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61307)
2023 Takeuchi TL6R...
TANK MANIFOLD (A58214)
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
154 (A52708)
154 (A52708)
2018 Multiquip AR-14 (A60462)
2018 Multiquip...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
