Winter Mower Storage. Drain the gas? Stabil? Start it once a month?
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #61
Well..... I have forgotten the alternatives listed in previous posts, other than using Stabil.
I never indicated that I needed, or wanted, 100 octane!
What I want, and need, is zero ethanol content!
Where would you suggest that I purchase non-ethanol gasoline?
You want non-ethanol gas, but you don't need non-ethanol gas.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #62
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #63
Your locale dictates IF you can buy it at all. In RURAL Iowa, Casey's sells it. Not available in Illinois or Indiana. Many outdoor equipment places sell it, but it's really expensive.
The state law here is: "No non-ethanol fuel may be dispensed from a pump"
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #64
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #65
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #66
I need non-ethanol fuel. I have two ATVs that often set for months. Before I switched to non-ethanol fuel, if I let either of the ATVs set for a few months I would have to clean the carburetor. Since I switch to ethanol free fuel I have had no problems.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #67
I am pleased to be informed what I "need"!
You could use Stabil in E10 and then you wouldn't be burning leaded fuel, and your engines would last longer. It's a lot less expensive as well. Therefore, the conclusion is you don't need 100LL, you want to use it.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #68
You're not burning 100LL avgas are you?
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #70
I have no experience with 100LL, race gas, or even "high" octane gas at all. But I do have to say that here in S Ca if I don't run my 2 cycles dry at the end of a usage...I will have carb problems once I try to re-start. My truck, and other 4 cycles, seem to be able to get through the off sessions. Although my truck is run almost daily and for my portable generator I have a valve set-up in my gas line to drain the tank once I'm through using it at that time.
It might sit unused for "months" and I dare not let ethanol gas sit in the tank because it "will" gum up the carbonator!! BTDT too often to bother with messing around any longer. I have found that the best way to avoid carb tinkering is just run "em dry and put 'em away. Sure it may dry gaskets some, but it absolutely doesn't gum up any more carbs! I like to be able to grab a machine when needed, put in fuel, pull the rope and do my work -- without having to take apart a carburetor, massage the engine, then an hour or two later get my task done. I use stabil. seafoam, marvel mystery oil, and blind luck to no noticeable results. After reading all the above comments I can't say that high octane gas is hurtful or helpful...but I believe I'll stay with my methods for now.
MossRoad you make good points but sometimes it just doesn't matter - a 5 to 10 minute chainsaw job turns into hours of frustration and tinkering. Perhaps (almost certainly) your gas is processed differently than ours or others and your methods work for you. They don't for me. Just saying a different perspective on this issue is always available and worthy of thinking about.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #72
We can buy non-ethanol gas right from our pumps at most filling stations. Most of the gas stations offer it in a standard octane gas, so you don't have to buy the higher octane pump gas. It costs a few cents more a gallon, but it's worth it, and it's all I run in my small engines.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #73
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #74
A bit too far for me to drive to Bismark!
Slightly over 1800 miles!
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #75
I'm sure it varies from state to state. We can get premium no-E (at a very premium price) but that's it, not all stations offer it. One more underground tank to install & maintain. I'll use it to make 2 stroke mix, or in something that sits a lot (ATV, snowmobile) but it's too expensive to use in something that gets used a lot like a lawnmower.
I'm in the "run it dry" camp for seasonal equipment. A little planning ahead to make sure you're pretty much down to fumes at the end of the season isn't that big a deal.
I'm also one who does oil, filter, etc. changes at the end of the season so when it comes time to start using it again just add gas & go.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #76
Good info!
Exactly: Precisely defines the issue with non-ethanol gas in my state!.
Can only be purchased in 5 gal. sealed cans at $15 per gallon.
But: Site lists local airport also: $6 per gal. 100LL.
Of course, I could also drive 6 hours round trip, to neighboring state.
More then all of those listed on that web site sell it in 5 gal cans or quarts. I only know of a few stations that have it at the pumps and its racing fuel and $$$.......
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #77
It痴 available at certain gas stations here from the pump. I think non-ethanol is about 30 cents more per gallon but worth it from my experience.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #78
In my SCAG zero turn I simply use ethanol gas (+ Stabil), and let it sit over the Winter.
In my chainsaw, and 3500W generator I use 100LL aviation gas.
That stuff keeps forever, and does not get gummy, or eat fuel lines. I sometimes do not start the generator for 3 or more years.
I do not want to rebuild any carbs.
You could try following your generator's operation instructions for long term storage, too. I'm fairly certain it will tell you to store it with no fuel in the tank and if you do, to use fuel stabilizer.
/ Winter Mower Storage. Drain the gas? Stabil? Start it once a month? #80
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61306)
Bulk Lot of NEW...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61306)
2006 Heil Tanker...
