2025R MMM height issue
/ 2025R MMM height issue #1
Hambone
Southeast Kentucky
JD3032
Hey All,
Long time no hear.
My MMM height control is acting up, wondered if anyone had any ideas before I tear into it
Yo can set everything just fine, but it won't stay where you put it after mowing a bit.
Say I put it at 4" and take off, before you know it you are at 3"
Any ideas? Not really looked into this issue yet.
I did do a forum search but didnt see anything.
Thanks in advance
/ 2025R MMM height issue #2
I’m not sure I can answer but have a couple of questions. Generation I or II 2025r? Independent deck lift?
I知 not sure I can answer but have a couple of questions. Generation I or II 2025r? Independent deck lift?
Thanks for replying.
Not sure, it is a 2019 model with 60D deck.
Deck lift is a rod from 3pt
/ 2025R MMM height issue #4
Hambone
Find out what is slipping to cause such a change.. then let us know.
A clue for us would be what do you have to adjust or change to get it set back to 4" height again, when you say "put it at 4".
You then have to raise 3pt up, which brings up deck, then turn dial back to 4, then let 3pt back down.
Then after mowing a short distance the dial will turn down to 3, thus the deck being too close to ground.
Hope that makes sense.
I am going to try to get it into garage today or tomorrow
/ 2025R MMM height issue #6
Likely problem under the knob that sets and holds the height setting.. look for the spring clip (#26) being in place and not broken as seen in this schematic.
That clip is part # LVU15992
Thank you!
/ 2025R MMM height issue #8
For your info, you have a generation II, and the standard deck lift, not the independent.
/ 2025R MMM height issue #9
So dodge man, are you saying that the adjustment knob for height setting reply #6 does not apply?
Not sure what you are adding to information needed by the OP.
/ 2025R MMM height issue #10
No I’m not saying that sorry for the confusion. The OP probably didn’t know that there were two generations of 2025r and three different deck lift options which may or may not affect how the height setting works.
Howdy,
Nope, I sure didnt know that. I had a 2210 for 15 years and went to the 2025 about a year and half ago.
Really like this thing, but I sure don't like issues. This is the first hiccup.
See attached.
Any idea why this happened??
/ 2025R MMM height issue #12
If I’m looking at it right it looks like the teeth are worn off, probably where you want it set at. Why? Beats me but the made in China doesn’t boost my confidence. I wonder if it wasn’t quite engaging correctly and kept giggling back and forth and caused premature wear. How many hours on your tractor?
/ 2025R MMM height issue #13
Obvious that it is the problem, and needs to be replaced.
Good pics..
What is your plan for the fix?
My guess is someone tried to raise the deck by turning the knob for height setting.
Right at 100 hours, not very long.
Yes, going to order new China part, get it installed. Doesn't look too bad after you remove LR tire.
Have to make sure everything is lining up correctly. Maybe the arm that rest on that part is not fully where it needs to be?
Won't be able to tell until part arrives
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
GENIE SUPER LIFT CONTRACTOR (A60736)
GENIE SUPER LIFT...
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61307)
2017 Yale GLC050VX...
