2025R MMM height issue
   / 2025R MMM height issue #1
Hambone
Platinum Member
Southeast Kentucky
JD3032
Hey All,
Long time no hear.
My MMM height control is acting up, wondered if anyone had any ideas before I tear into it
Yo can set everything just fine, but it won't stay where you put it after mowing a bit.
Say I put it at 4" and take off, before you know it you are at 3"
Any ideas? Not really looked into this issue yet.
I did do a forum search but didnt see anything.
Thanks in advance
   / 2025R MMM height issue #2
I’m not sure I can answer but have a couple of questions. Generation I or II 2025r? Independent deck lift?
I知 not sure I can answer but have a couple of questions. Generation I or II 2025r? Independent deck lift?
Thanks for replying.
Not sure, it is a 2019 model with 60D deck.
Deck lift is a rod from 3pt
   / 2025R MMM height issue #4
Hambone
Find out what is slipping to cause such a change.. then let us know.
A clue for us would be what do you have to adjust or change to get it set back to 4" height again, when you say "put it at 4".
You then have to raise 3pt up, which brings up deck, then turn dial back to 4, then let 3pt back down.
Then after mowing a short distance the dial will turn down to 3, thus the deck being too close to ground.
Hope that makes sense.
I am going to try to get it into garage today or tomorrow
   / 2025R MMM height issue #6
Likely problem under the knob that sets and holds the height setting.. look for the spring clip (#26) being in place and not broken as seen in this schematic.
That clip is part # LVU15992
Thank you!
   / 2025R MMM height issue #8
For your info, you have a generation II, and the standard deck lift, not the independent.
   / 2025R MMM height issue #9
So dodge man, are you saying that the adjustment knob for height setting reply #6 does not apply?
Not sure what you are adding to information needed by the OP.
   / 2025R MMM height issue #10
No I’m not saying that sorry for the confusion. The OP probably didn’t know that there were two generations of 2025r and three different deck lift options which may or may not affect how the height setting works.
2014 Triple Crown 10ft S/A Utility Trailer (A51694)
2014 Triple Crown...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2024 KMC 7406 (A53084)
