Compact with 150 hours on it, never been serviced. Avoid?
/ Compact with 150 hours on it, never been serviced. Avoid? #1
tallguy104
Australia
B2301
Hi guys, I'm in the market for a sub-compact or compact like the Kubota BX / B series.
I'm looking around at the second-hand tractor market locally, and I've come across this 3 year old B2301 with 150 hours on it.
It's never had a loader attached to it, just been used for mowing and plowing.
I'm a bit of a newbie when it comes to owning tractors, but I did follow the steps in this video on how to evaluate a used tractor.
It looks like it's never been serviced. The owner services his own machinery, and when I asked he couldn't tell me where the oil filter was (not a good sign!!). When I found it, it is the grey painted filter, presumably the one that came with it from the Kubota factory...
I know first service is supposed to be at 50 hours.
Below is a photo of the colour of the engine oil off the dipstick:
Radiator screen had a fair bit of grass in it (photo taken after it was given a quick clean).
Air filter had a fair bit of grass and dust caked on it.
So it looks like it's spent the first 150 hours of it's life being unloved. I doubt it's ever been serviced and it looks like it's air filter and radiator screen haven't been cleaned, possibly ever.
My first question is, at 150 hours will this neglect make any difference? Or is it still so young it will have had minimal effect on the health / longevity of the machine? Anyone?
The other concerns that stood out:
It's been bumped into a fence post so the front headlamp cover and grill is cracked:
We live in a coastal area, so rust can be an issue if not garaged. The owner claims it has been, and I can't see much rust on it, except for this plate just under the seat...?
Here's a few more photos generally:
/ Compact with 150 hours on it, never been serviced. Avoid? #2
Those front tires sure looks worn for 150 hours...... Good luck....
/ Compact with 150 hours on it, never been serviced. Avoid? #3
It always helps to have a general location in your profile.
By "plowing" I assume that was pushing snow. It would explain the wear on the front tires, operating in 4WD on asphalt/cement, and the rust from salt (it may have had a salt thrower on the 3pt.). When pricing, include the cost of an FEL if you want to add one latter, it can get expensive.
Sorry, have updated profile now. We're actually in a snow-free part of the world, so by plowing I meant plowing soil, with some kind of home-made tow-behind gadget the owner said.
/ Compact with 150 hours on it, never been serviced. Avoid? #5
By "plowing" I assume that was pushing snow. It would explain the wear on the front tires, operating in 4WD on asphalt/cement.
Or filled rock hard with air and only wearing down the center.
/ Compact with 150 hours on it, never been serviced. Avoid? #6
I'd pass if for no other reason that it doesn't have a loader. If you ever decided to move on, I'm guessing 8 out of 10 prospective buyers will pass for the same reason.
/ Compact with 150 hours on it, never been serviced. Avoid? #7
If everything seems to be in good working order and the engine oil isnt burnt you should be fine. Just purchase it according to its condition. A unserviced tractor hasnt the value a fully serviced one has. Also ask if the owner will hold it for you while you have a oil sample tested. Send the sample in next day delivery and call the company that tests it if they will expedite the testing and call you when done. If no wear is shown it should be fine. Be sure to run a cleaner through the motor before filling it back up. After a couple hours of use drain and fill again.
/ Compact with 150 hours on it, never been serviced. Avoid? #8
My first thoughts too, even if over inflated.
That and a little around the 3 point make me think it has seen a lot of humidity.
As to the hours, it probably has seen a lot of continuous running time while mowing. If he has a big yard, and the mowing season is long, 50 hours per year means it hasn't been getting short runs contributing to sludge formation. In engineering circles, 150 hours would be somewhat equivalent to 15,000 km on the engine. While not the best, I wouldn't loose too much sleep over that one factor. I'd be more concerned why it's being sold and if the answer sounds reasonable.
If you want a loader, this is likely not the tractor for you!
OEM loaders become very expensive as an afterthought.
How does the asking price of this B2301 compare with the price of a new B series ?
/ Compact with 150 hours on it, never been serviced. Avoid? #9
If the hours are correct, it’s not to late for maintenance. Diesels tend to turn oil very black so that’s not unusual. Like already said if you need a loader it needs to be cheap.
/ Compact with 150 hours on it, never been serviced. Avoid? #10
Wholeheartedly agree. 150hrs is not too late for a 'servicing'. If it's the tractor you've been looking for you should get it at a very reasonable price, especially if you voice your concerns. A FEL will be easy enough to access from a Kubota dealership if you want one... I'd go with OEM filters & oil. You'd be close enough to the 200hr hydraulic fluid/filter maintenance that it'd be worth doing everything at once.
If you do get this tractor I highly suggest adding "Fuel Doctors" (available at Supercheap Auto) additive to the diesel. It will help.
Yeah I was actually going to buy the same model brand new.
I do hope no-one has been fiddling with the hour-meter. Besides the worn front tyres, which I'm hoping is down to over-inflation, any thoughts on whether the rest of the machine's condition could be in line with ~150 hours of use? I believe he has been mowing a lot of lawns with it primarily (his own few acre property, plus several neighbours and friends).
He's selling it for ~65% of the new price. So around here they sell for ~$21,000 new, and he is looking for $14,000 (Aussie dollars). Sound like the right price?
/ Compact with 150 hours on it, never been serviced. Avoid? #12
He's selling it for ~65% of the new price. So around here they sell for ~$21,000 new, and he is looking for $14,000. Sound like the right price?
Considering the obvious neglect, I would shoot for 50%
/ Compact with 150 hours on it, never been serviced. Avoid? #13
By the rust around the bolt holes, I would think there’s been something attached to the front frame.
/ Compact with 150 hours on it, never been serviced. Avoid? #14
Rust around bolt holes on front frame suggest something mounted on the front.
Mower deck pulley covers missing.
Side discharge cover missing.
Top half of ROPS missing.
Cross brace behind set bent.
Looks like it was rode hard and put up wet.
He said he has the rest of the ROPS, and I think he mentioned something about some deck covers he has set aside. I will check.
It does indeed look like it's been knocked around a lot in its short life. Quite a lot of scratches and dings in the paint work.
The previous owner had to drive it along a bitumen road a lot, to get to other properties, so I'm guessing this explains the tyre wear (?)
/ Compact with 150 hours on it, never been serviced. Avoid? #17
Well there's your answer... turf tyres + bitumen = more tread wear than usual.
Very simply put; R1 (Ag tyres) have the 'deepest' tread and are designed for pulling traction and are ideally designed for 'field work'. R4 (Industrial tyres) have a not-so deep tread, are wider and 'softer' than a R1 and can handle asphalt/bitumen surfaces better. The tractor you're looking at has R3 (Turf tyres), the softest of tractor tyres and the least 'aggressive' tread.
So, you need to be honest with yourself and what you want to do/accomplish with the tractor you need. R1 tyres do not fit R4 wheel rims. I can't honestly say that R3 rims would fit an R4 tyre, but I doubt it.
/ Compact with 150 hours on it, never been serviced. Avoid? #18
Would you want to live where the seller lives? If the rest of the sellers stuff looks used and abused that's a good indication of what you are buying at the fire sale/auction.
/ Compact with 150 hours on it, never been serviced. Avoid? #19
"Would you want to live where the seller lives?"
That is often the BEST way to assess the condition of used equipment!
/ Compact with 150 hours on it, never been serviced. Avoid? #20
As the OP is a new member, I was able to quickly review his postings. His original concern was saving time mowing a 3-acre former sheep paddock, and the consensus was that a zero-turn would outperform a tractor. So far, he has not broadened the proposed scope of its use. In fact he reduced the scope as snow removal is out. From the pictures and observations of others it appears the OP's characterization of "unloved" was spot-on. In my mind the questions are: At what point does a bargain on a less-than-ideal machine become viable? If time is important, will the machine in question require more attention than the OP is willing to devote?
