replacing fuel assembly
/ replacing fuel assembly #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all,
My last post was about my diesel that leaked when removing the bowl even though the fuel-shut off was closed. It was noted that in-order to prevent water in the fuel from condensation, to keep the tank full. This is where my fuel still came out when shut-off valve closed and cleaning the bowl. As noted, the fuel did not leak now when the tank was on 3/4 full. But now I have a new problem.
When I went to the shed, I noticed the dirt under the engine area looked wet. I thought either an oil or hydraulic leak. When I pulled her out, I learned it was diesel.
After shutting off fuel and removing bowl, it did not leak like before, but when reassembled, it was leaking from the threaded area. Yes, the o-ring was in and I even added silicone. There's 2 places where the threads are flat and it's leaking from those areas...one drop about every 8-9 seconds.
I am thinking it's time to replace the whole assembly. If not, is there another solution? If the assembly, are there any video's or tips on replacement? One ques is do I need to drain the fuel tank or is there another way to prevent fuel from leaking?
Thank you and pls let me know if you have any questions.
Regards,
tstex
/ replacing fuel assembly #2
First might replace the O-ring. I have had worn O-rings not leak and new looking ones leak. Don’t over tighten. Check for burrs even with new parts.
Thanks / I値l try a new o-ring first and see how it goes. I値l also take a pic of the upper assembly where the threads are to show where the thread look smooth.
I did tighten a like more than normal. I would guess extra torque pinches o-ring & thins it out?
/ replacing fuel assembly #4
Particularly O-rings sealing flat surfaces with silicone grease. I’ve only used clean fuel for Oring lubricant for this filter. Doesn’t seal on the threads if like mine.
/ replacing fuel assembly #5
I don't have a Kubota, however, I thought my fuel filter assembly was leaking from the large O-ring also. But I was wrong. My valve used to turn the fuel off, has a replaceable "packing", it was discreetly allowing fuel to drip down, onto the threaded nut that hold the bowl against the large O-ring. Maybe you have a similar problem!
Found the problem. Thanks for your reply joh.
I pulled the fuel bowl and under the top of the fuel assembly, there was some crud under the area where the lg o-ring sets up. I removed the crud w very sm screwdiver, then replaced older o-ring w new one, then hand tightened. Assembled and opened **** off valve and no leaks !!! 👍.
Thanks again to all - Tstex
2017 Gravely ZT-X 52in Zero Turn Commercial Mower (A64194)
2017 Gravely ZT-X...
PALLET OF BLOWERS, BATTERY CHARGER & MISC (A64278)
PALLET OF BLOWERS...
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
6' SCRAPE BLADE W/ SLIDE, 3PT (A64278)
6' SCRAPE BLADE W/...
2022 EZ-GO ELITE...
UNUSED PARBREAK GCC56 3 PRONG HAY SPEAR (A65055)
UNUSED PARBREAK...
