Dump Trailer build
/ Dump Trailer build #121
Guys, can you make trailer like that legal, that can be used on road (with license plates).
On our side of the pond, that's almost impossible.
/ Dump Trailer build #122
Any trailer can be made road legal, just have to have right bearings and trailer lights.
I had to look up where Croatia was, quite a long ways from here and there and from where it is I would've though it would be a different language, some country pics would be nice.
data=QH8v6O_c7TAPKaCfI5Fev85IOEqGfZvVr3WhECn0NkIrUQ3I_xfi43R4lWBBjbeybbqK0ehHnYxG10FF2zxhN5JSouK.png
/ Dump Trailer build #123
Requirements can change state to state, registering a homemade trailer is fairly easy in my state of Virginia, other states it can be more difficult to almost impossible.
Ohio is super simple. We have to take it somewhere with a registered set of scales and get an official weight. Then it can be titled as a homemade trailer.
/ Dump Trailer build #125
Virginia we just have to get the paperwork/ vin tag, then a state trooper comes out and verifies the vin plate. Once it's signed off by the trooper you can title and register it.
/ Dump Trailer build #126
In Washington, if you build or buy a homemade trailer, you must provide original receipts for all major parts in order to get a title. If you don't have them, you can get plates, but have to wait 3 years to get title.
http://www.wsp.wa.gov/traveler/docs/cvd/170_129.pdf
Bruce
/ Dump Trailer build #127
Thanks to you all :)
Here is simaliar to @bcp -s post, but without happy end.
/ Dump Trailer build #128
Doe-bra-din.... Question...
Is the license and registration different for the trailer if you pull it with a car, than if you pull it with a tractor as an implement ??
For us if it’s behind a tractor it doesn’t need license. If you are going to use it behind a vehicle for highway use then it does need license.
/ Dump Trailer build #130
Maiden voyage. Trailer was loaded with firewood before stacking 10 posts and 65 1x6s on top. It handled the weight awesome.
Still need to come up with a name for the trailer.
Yeah thats good but we all know what the real test is and what I want to see.................. I suppose it it is a good idea to not go the same route as the Titanic....:eek:
Dump 1 yard of dirt at moderate speed with no strain on the frame one time all the time = satisfactory. 1-1/2 yard of dirt = well done. 2 yards = outstanding and impressive. More then 2 yards =1 2 3 and unbelievable from the materials that was used...........
I was told my 5' bucket when rounded = 3/yard so if you put in 3 scoops you should be aprox 1 yard and gravel makes an excellent choice, bring me over 3000 yards when you get around to it.......
Oldpath. What test are you wanting to see.
Oldpath. Lol dumb question. How many 5ft bobcat scoops is that. And would gravel suffice. I have a buddy that works at the gravel yard that told me to come play
A 5’ bobcat scoop is probably 1/2 yard.
Uh................. no I haven't forgot the gravel test, wood is good, but a big load of gravel is best......
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2019 BOBCAT T740 SKID STEER (A62129)
2019 BOBCAT T740...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
