airbiscuit
Super Member
- Joined
- Aug 28, 2004
- Messages
- 7,664
- Location
- NW Wisconsin
- Tractor
- New Holland T2310 (40hp), Kubota L3010 GST, New Holland TC21DA *** Previously - Farmall H, 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
I would check that the choke plate is correctly returning to the closed position when the engine is off.
This would be my first suggestion also. Make sure cable hasn't slipped and choke is working as it should.
A couple years ago, I bought a brand new Snapper lawn tractor that acted like yours. I even put a check valve on it to keep it primed. Dealer said they just run lean. I took the air cleaner off and discovered the throttle/choke cable was mal-adjusted and didn't close the choke completely. Adjusted it so the choke would close, and problem solved.
