MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,209
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
The two identical threads have been merged to avoid cross-conversations. Please continue the discussion.
What hasn't been mentioned is that starter fluid (either) is one good way of destroying small engines.
(Like putting a rod thru the crankcase.)
It is OK on big heavy cast iron diesel engines but murder on most smaller ones.
A lot of smaller diesel's are simply re-purposed gas engines and not quite up to the higher compressions.
I always use an unlit propane torch to start a stubborn engine.
Like anything else, you have to use it correctly. I had an 8 HP Tecumseh chipper shredder that was almost impossible to start without starter fluid. I would give it a very small squirt, replace the air cleaner and it would start very smoothly with no problem. After about 10 years, I decided I didn't need it anymore and sold it. I included the starting fluid and disclosed that it was a hard starting engine.
I would check that the choke plate is correctly returning to the closed position when the engine is off.
It probably had a sheared flywheel key. Most likely from someone using starter fluid.:laughing:
One backfire is enough to shear a key and ****** timing. That's all it takes to make an engine hard to start. It all begins with a bad plug, fuel or air problem. Starter fluid is NOT a fix. :laughing:
