Why does starter fluid cure my no start? What is the issue?
   / Why does starter fluid cure my no start? What is the issue? #11
Re: Why does starter fluid cure my no start?
I’ve worked on engines all my life but never done this! Do you just give it a squirt or let the propane run continuous? I’m intrigued!
Well known trick. Kinda replacing additional fuel choke provides wid already vapor propane.
Lot of engines been sitting gas evaporated from carb bowl so you gotta crank to fill bowl before engine starts. Replace gas wid propane down carb neck engine generally start quick.
Torch like Bernzo work good to about 10 horse Bigger engine need more propane so use bigger torch.
I got old beat up Bernzo pulled torch head off stem and connected 1/4 hose to neck. Hose goes into air neck of carb. Much more convenient den holding torch. Also eliminates propane restrictor torch uses to meter gas.
Spin engine to lube crank and bearings, maybe 2 seconds den open valve on Bernz. Generally engine starts right up.
Good way to check out engine you just met. You got no idea engine got spark or plugged carb so use propane into carb air intake. If you got spark engine will pop and try to run. You got enough propane engine will run.
Slightly different method used to light up Diesel in cold.
   / Why does starter fluid cure my no start? What is the issue? #12
It's not much different than running a gas generator on propane by aiming it into the intake port and adjusting the flow.
(see TouTube & post #10)
   / Why does starter fluid cure my no start? What is the issue? #13
I would check that the choke plate is correctly returning to the closed position when the engine is off.
   / Why does starter fluid cure my no start? What is the issue? #14
An unlit propane torch is handy for finding a vacuum leak also.
   / Why does starter fluid cure my no start? What is the issue? #15
Check your choke & low speed jets too. A cold engine needs more gasoline to make up for the fuel that condenses on the cold metal of the intake, carb, etc.
   / Why does starter fluid cure my no start? What is the issue? #16
I'm disappointed. I thought it was my creation. Still one that likes to use my brain and think of solutions.
Been meaning to add some hose to an old propane torch and add an aligator clip, so one can clip it near the carb throat. Otherwise it's often a two person operation. One holding the torch.
Great for getting some garbage two stroke going for the first time in the season. Or you could just pull on it until your arm, pull cord or patience gives up.
But to answer question. Yes, continuous. Sometimes runs as long as you hold propane there, and starts to die when you take it away. Friend who works for a Business including a large small engine shop just laughed at me. Like, it runs on Gasoline, what are you talking about propane? I showed him though.
   / Why does starter fluid cure my no start? What is the issue? #17
Don't get it addicted to ether, it is not good for the engine in large amounts or extended periods. I've seen too many engines destroyed by it, find the problem and fix it right. Something that new about has to be something simple, I would start by replacing old gas then filters, air and fuel, spark plug and wire etc. Always start with the easiest and least expensive stuff and work your way up.
   / Why does starter fluid cure my no start? What is the issue? #18
I never tried an unlite torch but for years WD40 worked about like starting fluid. Then it didn't work at all.:confused3: I figured like everything else,manufactur took "good stuff" out so I went back to starting fluid. Found out propane was used early on as the propelant then stopped for liability reasons. Never occured to me to just us a torch.
   / Why does starter fluid cure my no start? What is the issue? #19
It is possible it's not getting fuel due to fuel pump or vacuum. Getting the engine to begin running could move the pump fast enough or generate enough vacuum to establish a fuel flow. I have a Craftsman garden tractor that sometimes doesn't want to start. I'll dribble a bit of gasoline into the carburetor and it starts right up. It may then start fine the rest of the season, or I may need to repeat the process the next week. I'm thinking of an electric fuel pump with a switch to assist starting when required.
   / Why does starter fluid cure my no start? What is the issue? #20
How do I check the fuel pump?
How do I check the vacuum?
In the meantime, why is it better to use gas and not ether as the starter fluid ?
Don't use gasoline. There're better/safer alternatives.
UNUSED FUTURE 16" AUGER (A57193)
UNUSED FUTURE 16"...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A57193)
UNUSED FUTURE MINI...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
John Deere 6110M (A53317)
John Deere 6110M...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
