John Deere 401C Hydro trouble
/ John Deere 401C Hydro trouble #61
Priority valve on JD ag tractors has less hyd lines attached to it than JD industrial tractors. Look closely at the photos Zebra5 posted in his reply @ # 56 in this thread
/ John Deere 401C Hydro trouble #62
I've seen that, the 401D PCV has no big hole but there's a O-ring for it(to make a seal). Where does the extra psi escape to?
/ John Deere 401C Hydro trouble #63
Due to my very limited JD ind tractor hyd experience & no access to a JD ind tractor tech manual my guess that oil flow you refer to travels via the extra hyd line that ag tractor doesn't possess.
Technically there should be no extra psi because JD closed center hyd system psi is determined by stroke control valve in frt hyd pump not by pressure control(priority) valve.
/ John Deere 401C Hydro trouble #64
I've ventured into a unknown hydraulic world when I took possession of this JD 401C, it's a real eye opener :shocked:
I'm slowly learning the ropes because I'm slow learner ;)
/ John Deere 401C Hydro trouble #65
JD closed center hyd systems are unique. I was employed by a smaller JD dealership & helped diagnose/supervise repair hyd problems for a large majority of the 21 yrs I was there. I've learned even more since I left dealership. Just remember "good diagnostics is a must" before any parts are replaced.
It would have been wonderful if the tractor discussion forums had been available back in the 60's-late 80's !!!!!
/ John Deere 401C Hydro trouble #66
I pinpoint the culprit of my FEL and steering woes on the Pressure Control Valve. Local dealer is unable to get one or kit and says they're discountinued. Any other source to find one. What's the correct part #? I could fabricate another style into the system by blocking off the transmission two holes with a plate and maybe using one hole for return of over pressure.https://www.tractorbynet.com/forums/asset.php?fid=584263&uid=344904&d=1603539926
IIRC, the two holes in the transmission case are for feed to the rockshaft valve and a bleed passage at the rear end of the valve to prevent hydraulic lock of the internal valve.
On your PCV where does the swivel female connector line go to? AG tractors do not have this connector. The one above it is oil in from the front pump. The one at the rear is oil out to SCVs.
/ John Deere 401C Hydro trouble #67
I've bypassed it and everything was working like it suppose to. I reconnected it after taking it apart to make sure no dirt was in it. I also plugged the rear selector to take it out of the equation and it's back to the woes again.
What do you mean by "plugged rear selector" ? Did you plug the rear fitting on the PCV?
/ John Deere 401C Hydro trouble #68
My knowledge of JD "utility tractors" is limited BUT on AG tractors with a similar pressure control valve this PC valve doesn't control system pressure. As I previously stated PC valve provides hyd priority pressure to power steering. The stroke control valve in frt hyd controls system hyd pressure. Does your 401C have a 3 pt hitch??
You are correct the PCV does not control pump pressure.
What it does is close oil flow to rockshaft and SCVs if pressure drops below 1700-1800psi (AG tractor) to give priority to steering (all flow goes to steering) until pressure builds back to above 1700-1800psi.
/ John Deere 401C Hydro trouble #69
Isn't 3 pt hitch supplied hyd oil via a galley in trans case supplied by hyd pressure from pressure control valve?
Yes, internal passage to rockshaft cover
/ John Deere 401C Hydro trouble #70
Could the small hole of the transmission feed the rear selector is my question?
I'm gonna tap my new pressure regulator into the existing defective pressure regulator to direct over pressure flow and T the working flow towards the rear selector if needed.
By rear selector do you mean rockshaft/3point hitch? Or SCV?
One hole feeds the rockshaft, internal passage. The other is bleed off for PCV's internal valve. Should be the rear most hole.
/ John Deere 401C Hydro trouble #71
How did you bypass it?
Simplest way I can think of to defeat/bypass it is to remove the internal spring. Then it could never shut off oil flow to rockshaft or SCVs (if it has any)
/ John Deere 401C Hydro trouble #72
I agree with Zebrafive. I've never given any thought to bypassing PC valve on a 20-55 series utility tractor. In normal hyd operation if stand by pressure gets below 1700 psi PC valve closes to give power steering priority hyd pressure by blocking oil pressure to scv & RS & FEL if equipped.
I suppose to operate tractor in the absence of PC valve one could bolt a flat plate to cover holes in the side of trans case.
/ John Deere 401C Hydro trouble #73
I bypassed the RS by plugging the rear bottom fitting going to the RS. I bypassed the PCV by connecting the inlet(from front hyd pump) to the outlet(bottom front fitting) going to FEL directly hose to hose(PCV was left out of the sytem but still attached to the transmission. Hope I'm explaining it correctly. If my RS is not functional, I can use a 12V actuator to operate my snow blower chute.
/ John Deere 401C Hydro trouble #74
SCV's can be made functional without rockshaft functioning BUT isn't snowblower mounted on 3 pt??
/ John Deere 401C Hydro trouble #75
So forward lower fitting goes to the loader.
Lower rear fitting to rockshaft, and nothing else?
So I ASSUME, no rear SCVs?
When you had the PCV off, did it have one or two passages on the mounting side? I suspect, at least the bleed off.
Did the transmission case have passages to match?
Maybe Industrial version has the internal passage to the rockshaft that is not used (since you say rear from PCV goes to rockshaft, I ASSUME an external line), and the internal passage is somehow leaking to sump?
Have you tried bypassing the PCV and connecting direct to rockshaft, leaving loader disconnected? If this brought back problems, rockshaft or it's valve is the problem. If no problems, put in a TEE, main pump to loader and rockshaft, and plug all connections on the PCV. Leave the PCV on the tractor.
/ John Deere 401C Hydro trouble #76
Rear SCV, is that the control for the 2/4 hydraulic hook ups at the rear for, like a direction control of the chute for a snow blower? RS is the Rear Selectors(or in your case as the Rear SCV) which I think you are referring as the rockshaft. I just need to use the wording in the right order, I'm slowly learning :thumbsup: I'll be slapping everything together as soon I get my PCV back from wear inspection. I will be connecting the Rear SCV just to see if it works from a plugged(bypassed) PCV or try a Tee. I do use the 3pt for the snowblower. There's two passages on the mounting side of the PCV including the transmission case.
/ John Deere 401C Hydro trouble #77
Rockshaft is referring to shaft that rotates in order to raise 3 pt hitch
SCV=selective control valve aka rear hyd remote aka rear wet lines(connections/breakaway couplers)
As usual I'm confused how are you utilizing 3 pt hitch with pressure control valve oil galley to rockshaft blocked off?
/ John Deere 401C Hydro trouble #78
It' the SCV that was blocked off. Rockshaft is not in this equation at all, eventually I will be on the same wavelength as the experts :)
/ John Deere 401C Hydro trouble #79
I was referring to your post where I thought you stated you had "pressure control valve" blocked off.
/ John Deere 401C Hydro trouble #80
Oops! I ASSUMED RS was for RockShaft. Also called 3pt hitch.
I use SCV, for Selective Control Valve(s), for the valve(s) that control quick connectors. What you connect your chute rotator to.
So when you blocked off the rear fitting of the PCV, everything was fine?
When you connected rear fitting back to SCV(s), you had problems?
Sounds like a SCV is leaking internally back to sump. bleeding pressure off?
Is/are the SCV(s) original to the tractor? Maybe someone replaced them with ones for open center hydraulics?
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
More info coming soon (A61574)
More info coming...
GE DEEP FILL WASHING MACHINE (A64281)
GE DEEP FILL...
2014 JEEP GRAND CHEROKEE (A64280)
2014 JEEP GRAND...
Caterpillar 988G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 988G...
2019 JCB 2TS-7T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 2TS-7T...
