Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc...
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #11
Being a 2016 does it have to use DEF?
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #13
What emissions equipment/systems do they have?
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #14
With DOC they use EGR.
overview
I just had to run the toolcat indoors so I could weld a receiver hitch on my ssqa>3pt adaptor. It was a cold start and I just needed to raise the lift arm and I'm amazed that it hardly smells at all. No smoke and no burning eyes. Nice.
Here's a used buying guide and history of changes for series and model years. This includes major changes from each series (A thru G series) and common things to look for when buying a used toolcat 5600. I mispoke at the 1:11 min mark saying the older ones have independent front suspension, they do indeed have a solid axle (like my chart shows) but up front they have coil springs and links to locate the axles vs the leaf springs in the rear.
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #16
Great video
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #17
Got a small ~2in snowfall on Christmas so took the opportunity to get some 4k and drone footage of the toolcat plowing.
   / Videos: 2016 Toolcat 5600 at work, mowing, tree stump, plowing, etc... #19
Nate, another great video!
I have a plow mounted on my M126x and equipped it with a snow foil. You should try one. They are an inexpensive way to keep the windshield clear and the snow rolling even better.
My Western plow on my truck has one, too. Love em for powdery snow
Oh man, thats a serious tractor...can tell by 3 steps to just get in! 😆 yeah i have thought about getting a rubber strip to bolt on the top of the plow. Probably should get around to doing it. Plow already has mounting holes. Maybe that will be another Nater Tater video! :cool2:
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
