Didn't "build it," but definitely DIY Man Basket...
/ Didn't "build it," but definitely DIY Man Basket... #1
Lunk
WI
Branson 4720H / BL200 Loader
If you have a set of pallet forks, buy one of those caged 270 gal totes. You can usually find them on CL for 35-75 bucks. Remove the 4 bolts holding the top bars on and pull the plastic tank out. Strap the cage (I use a 2" ratchet - way overkill) to the forks. You now have a man basket for trimming limbs, cleaning gutters or siding, or I'm my case helping pick apples before they drop. Not OSHA approved I'm sure, but as safe as you want to make it for sure.
If this has been posted before, my apologies. Just thought I'd post it after using it the other day.
Lunk
/ Didn't "build it," but definitely DIY Man Basket... #2
If one of your Loader hydraulic hoses bursts, a fairly common event on tractors over three years old, you will be dead meat in court when someone is injured.
You probably have some liability for posting this recommendation.
/ Didn't "build it," but definitely DIY Man Basket... #3
Yep works great have had the wife up in it many times. I put yellow safety chain on the entry side and I have chains at each corner bottom (visible in the attached photograph) that prevent the tote from sliding off the forks. I used the ratchet strap to tighten everything down.
/ Didn't "build it," but definitely DIY Man Basket... #4
I cut "doors" in mine to make it easier to get in and out. I need to make bars to go across the tops of the doors to make it harder to fall out accidentally. And add hooks by each door to keep the ladder in position.
/ Didn't "build it," but definitely DIY Man Basket... #5
wow, three years before a hydraulic hose breaks? that seems unheard of..... they make legit certified man baskets for forklifts/telehandlers
/ Didn't "build it," but definitely DIY Man Basket... #6
I didn't realize my hoses were 7 years overdue to burst. :confused3:
/ Didn't "build it," but definitely DIY Man Basket... #7
It’s not perfect but it’s a heck of a lot better than using a ladder. I’ll take the chance of hose blowing under fairly light load vs falling off a ladder any time.
/ Didn't "build it," but definitely DIY Man Basket... #8
My L48 TLB is now officially 14 years old, and appears to have all original hoses.
/ Didn't "build it," but definitely DIY Man Basket... #9
I spent many hours picking apples, pears grapes,... from the bucket of my father's Ford 4400. My uncle and cousins painted a house from the bucket. Yet knowing what I do now, I have reservations about it.
I asked him about it a few years before he passed away and he said that the chances of both hoses failing at the same time were slim. He generally knew what he was talking about when it came to farm equipment or anything else; if he didn't know, he wouldn't say anything.
That time he was wrong. Tractors are an open system so if something fails everything collapses.
Man lifts have check valves to hold cylinders in place if something fails. You can add the same to your tractor for a price.
Then again, how often has somebody had a hydraulic failure with somebody in the bucket?
I did use my loader tonight to fix the roof on my henhouse. As somebody else mentioned it was a lot safer than leaning out from a ladder ... which is what I used to get up into the raised bucket.
/ Didn't "build it," but definitely DIY Man Basket... #10
I popped a hose on my roughly two year old backhoe this Fall. It was the Power Beyond hose that couples back into the tractor when the BH is off.
Not sure what would have happened if the loader had been up with a load. I have a tote basket with a door cut in. If I plan on doing much, I would use a 2x4 or similar under it.
/ Didn't "build it," but definitely DIY Man Basket... #11
You could of tied a rope to the joy stick and lifted yourself up...........:laughing:
/ Didn't "build it," but definitely DIY Man Basket... #12
I've used this for quite a while. Same idea. Much safer than a ladder. I could be hit by a meteor or more likely a moron driving and fooling with a cell phone. I am not worried about a hose. Never get higher than a few feet anyway.
/ Didn't "build it," but definitely DIY Man Basket... #13
I've got the same setup and use it all the time.
That said, is there a cylinder prop that can be used to not allow the FEL arms to drop if a hose were to burst? As I gotten older, I realize I am not as indestructible as I used to think I was! Still on the mend from a ladder collapse incident 2 months ago that left me clinging to the new barn roof 20' up, don't need any more equipment failure accidents.
/ Didn't "build it," but definitely DIY Man Basket... #14
A hose could break! Use something safe...like climbing a ladder!
The basket is much better for picking apples than the system we use. I usually lay a couple planks across the pallet forks and tell the wife to make sure she doesn’t step on the end of the plank beyond outside the width of the forks.
Don’t get me wrong, I’m not totally safety unconscious, I did take some bailing twine and fastened the boards down to the forks in case she did.
/ Didn't "build it," but definitely DIY Man Basket... #15
How difficult would it be to rig up a second set of controls in the basket? (Ducking and running) :)
/ Didn't "build it," but definitely DIY Man Basket... #16
Considering you’d need all 4 functions and the position of the platform is changing it would be pretty hard. I don’t see much gain anyway. You’d need to be able to move the tractor to gain much.
/ Didn't "build it," but definitely DIY Man Basket... #17
Lunk
I like it. Your tractor is much cleaner than mine
/ Didn't "build it," but definitely DIY Man Basket... #20
Re: Didn't "build it," but definitely DIY Man Basket...
I agree that it would take some "doing" and the gain would probably make it not worthwhile.
It is, however, interesting to think about what would be required to make it work. A tractor with hydrostat, power steering and self leveling loader would be a good start. A gimbal mounted bucket in lieu of a basket would seem to be a good option and that might be true even with a "two person" setup for safety. (I could see the tractor operator hitting the bucket dump by mistake.)
So, after further attempts to make this all complicated, a quick-attach boom type device with the gimbal mounted basket might be feasible for two person type setup. Yes, the safety and liability implications are horrendous anytime our feet leave terra firma.
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A63118)
Mahindra 4550-4L...
2008 Peterbilt 379 Semitruck (A64047)
2008 Peterbilt 379...
