Super nice Kubota excavator
/ Super nice Kubota excavator #42
For $17K you can't expect it to be a Swiss Army Knife. It's a very nice sized and capable Excavator priced cheap.
Yeah... I know. I stumbled on it on my IPhone while waiting to be loaded at the quarry.
I need a way to cut brush, higher than a bush hog, quickly, without hand labor. Started looking and Bammo there it was! The dig features it has are real helpful too, but its brush cutting up high thats the ticket for me. If theres not enough pump, then I will have to move on.
I thought for 17K and the cost of maybe a used brush cutter, I could swing it....
/ Super nice Kubota excavator #44
If it wasn’t a pretty good haul to New Jersey I’d give serious consideration to buying that.
/ Super nice Kubota excavator #45
I have all winter off from work...........
I have not worked at all for the past 20 .... Winters, Springs, Summers, and Falls!
Allentown, PA is 374 miles (6+20) from my house.
It’s north of A town a bit. 1.5 hour from me.
Great.... now I have Billy Joel’s “ Allentown “ stuck in my head :laughing:
/ Super nice Kubota excavator #47
GO! GO! GO! .....check it out!
/ Super nice Kubota excavator #48
Your closer than me. :)
/ Super nice Kubota excavator #49
Allentown is in Eastern PA.
/ Super nice Kubota excavator #51
I go through there quite a bit on 78. Great hot dog joint right there as well... But, I already have an excavator... :confused3:
/ Super nice Kubota excavator #52
But......Why not TWO excavators ???
/ Super nice Kubota excavator #53
What did you pay for yours?
/ Super nice Kubota excavator #56
You can run a brush cutter on low or standard flow! You have to find the gpm of the machine and match it up to a low flow brush cutter. The new attachments are trending toward low flow with the exception of high demand, asphalt- concrete grinders and etc.
I currently run a 6' brush cutter on a low flow Kubota CTL and do not have any problems. My Kubota dealer set me up with this combo.
I have been looking at brush cutter for a few days off and I was kind of surprised ho low of a flow they will operate on. However, I don’t have any spec on the Kubota KH28L excavator, so I can’t really accurately pair a cutter to it. Some will run on 10-12 GPM. But would they be strong enough to cut back 4-6” thick saplings? How well would it cut and simultaneously run the dipper or the swing function?
Also no AC, so summer days would be awful in a cab with no AC.
/ Super nice Kubota excavator #59
I would guess that era machines were well before the ideas of an excavator doing anything but ditch digging and not have much excess capacity in the pumps. But that is a guess just based on what excavators were bought for in the US market. At that time, a "mini ex" was a rare bird in the US altogether.
On another note, I have a Ambusher rotary mower on my big Gehl SS with something like 28 gpm on the standard flow circuit. I know that this mower is not comparable to a *forestry mower but I'd estimate that your 4-6" goal would be unreasonable. I could be f.o.s. and be completely wrong, and perhaps I'm envisioning too much production from a low hp machine but you and I both know mowing-grinding up that kind of stuff requires HP and lots of it, particularly hydraulically driven motors.
* the small mowers available for small excavators that I've seen are basically a heavy flail mower, not the fixed carbide cutters.
I've been considering getting into a mulching service to off set my personal clearing needs for a few years now. My conclusions are for a small machine that can be moved by a 550/5500 size truck, a ctl has the power for production and hopefully a profit. This puts you into a $60-80k investment and that's in the used market. Also on my land a ctl is not the right machine, not enough ground clearance for my boulders that are scattered everywhere.
Wow, I sure can ramble on eh?:thumbsup:
Good stuff Rustyiron, but maybe some background and context would be useful here. I have 2 main uses
Cutting high brush and digging out rocks. So a SS would Hebb helpful, but less ideal than a mini ex.
Almost all my brush cutting falls into 2 categories: pond banks (steep) and field edges (branches). Skid steer not useful here.
While breaking my back cutting field edge branches 5-25 off the ground with a pole saw, I realized I needed a cutter with an arm that can reach up high and grind-off branches.
I also do 2 different customers annual large cuttings around streams and ponds. These are good paying jobs. However, I have to stand in canals or on pond banks to cut them with weed whacker and saw blade for weeks to complete them. The pond has a flat-top berm which a mini ex could be driven on. With properly weighted smaller mulcher head, I could sit in cab and cut pond on one side and canal on the other. I could also sit on dry ground and reach over swampy land with dipper stick. This would cut my weed whacking task down by 80-90% and allow me to keep the contract well into my older years.
Rocks:I cut about 250 acres of hay fields. Some fields have significant rocks and a few stumps which are deadly expensive to hay cutter. Removing them lowers risk of damage and injury.
There are other uses. I still build an occasional construction project where a foundation or footings are needed.
I have seen some KX161 and U45 models that are fairly affordable, but the KH28L was really clean and cheap. However, if the aux circuit doesnt have any GPM, whats the sense in buying it.
Also, I have a 200HP Massey Ferguson 7495 I could mount a front mulching mower on, but I don’t really have a lot of brush in open space to cut. Its mostly field edges.
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
