   / Your last generator Maintenance Run #4,611
Vibration???
Frame mounted it's the silicon hoses that flex...
   / Your last generator Maintenance Run #4,612
Yes, the beehive heaters outlast the immersion heaters... Unless they were the 1850W version. But the 1000W behives run for years.
C8.3’s came with 1500W immersion heaters that didn’t last but the B5.9’s had a 1000W version that lasted for years.
   / Your last generator Maintenance Run #4,613
I'm always learning but nothing bad to say about these units...
I look at replacing the heaters as maintainence...
No idea what a typical service life is on these Gensets... 25 years with 650 hours and over a thousand starts...
   / Your last generator Maintenance Run #4,614
In prime power it’s 30,000 hours but standby units really depends on maintaining coolant ph and additives.
30-40 years is about the max, hard to get parts quickly at that age.
   / Your last generator Maintenance Run #4,615
Looks like we will both retire around the same time... this Genset was my first big purchase.
All bets off if it gets regulated obselete.
Made the acquaintance of a man that made a good living exporting used Gensets all over the world that could no longer operate in certain areas of CA
I've got 50,000 hours on a German made Vacuum Pump and steam boilers and sterilizers and water heaters 25 years old... and airhandler 3ph 480v motors10hp and up...
   / Your last generator Maintenance Run #4,616
Maybe Cali has outlawed ethylene glycol.
..... I probably shouldn't even jest....
Rgds, D.
but ethylene glycol is green, so it would be part of the new green deal?
   / Your last generator Maintenance Run #4,617
   / Your last generator Maintenance Run #4,618
An antifreeze you could finally drink and not die?
   / Your last generator Maintenance Run #4,619
OK, guys here’s the problem. I have a Kohler 17 kW automatic standby generator, and twice now the generator has started up without sending power into the house.
The last time was just a couple of days ago, and what I did was go out and cycle the 70 amp circuit breaker. I did it while the generator was running, and I flipped it off and on once. Nothing. Then a second time, and Presto! Power was delivered to the house.
Any ideas why this happened? Should I install a new circuit breaker?
In prime power it痴 30,000 hours but standby units really depends on maintaining coolant ph and additives.
Many vehicles get scrapped up here because (coolant was never maintained) the heater core rotted and nobody wants to pay the labour to take the dash apart.....
ur will be on top of his situation, but coolant often gets ignored. Advantage goes to air-cooled in the small stuff, with only one fluid to neglect.....
Rgds, D.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
1839 (A51248)
1839 (A51248)
NEW  STARTER (A55745)
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A52706)
UNUSED RAYTREE...
