Your last generator Maintenance Run
   / Your last generator Maintenance Run #4,601
Thanks, mine is a 1000 watt and I'll experiment leaving it plugged in for a month when it's cold. We've been in the 30's to 50's (F) for highs lately and not concerned with starting at those temps. Mid to upper 20's overnight. If it cycles off at the water temp you mentioned I can live with that. The building is uninsulated, but I suppose throwing maybe a concrete "blanket" over it and tucking it in would not hurt things and maybe save a little power usage.
   / Your last generator Maintenance Run #4,602
Sorry, thought I read 1800W.
If your grid prices are like mine ($$) Rusty, I'd be looking at how fast your primary building looses heat.....
If you can tolerate a lag-time to start-up, something like a propane catalytic heater could raise your powerhouse interior temperature pretty quickly. Not quite as good a heat soak as continuous coolant heaters, but the gain would be pre-heating the "ambient" air with something like a 20-30 minute blast from a catalytic heater..... depending on your particular diesel, that might be enough.....
Rgds, D.
   / Your last generator Maintenance Run #4,604
   / Your last generator Maintenance Run #4,605
The 1800W is now 9 years old... The hoses come in a kit from Onan and are silicon and about 3" long just long enough to connect to the metal tubing...
According to the literature the heater installed in the prime rated 125kW Cummins Turbo maintains coolant at 140F.
Should the heater fail and coolant temp drops low coolant temp alarm.sounds engineering office and Director of Nursing office...
Coolant temp does make a difference in how well it starts.
   / Your last generator Maintenance Run #4,606
You must have the unicorn of heaters. I’ve never seen the high wattage beehive heaters last. I don’t think they even make them over 1500W anymore because the 5/8 hose just got too hot.
1500W and larger should be a tank heater with 3/4 or 1” ports and hoses in order to last.
   / Your last generator Maintenance Run #4,607
It could be the mild climate equates to less on time?
This is the second one after the first one melted after 5 years.
The freeze plug heaters were my nemesis...
The "Beehive" is frame mounted and the silicon hoses do get a workout when the engine shuts down.
I'll take a picture.
It was the dealer that suggested the Beehive after I complained of the short service life of the freeze plug heaters.
   / Your last generator Maintenance Run #4,608
Weird, my freeze plug heater in dodge has been replaced 1 time ...its a 1994 dodge. The 2004 F350 has the original heater. I wonder why yours go out so fast
   / Your last generator Maintenance Run #4,609
If a heater isn't surrounded by coolant for whatever reason, it's toast! The higher your heater is in the block, the more possibility of this happening.
Maybe Cali has outlawed ethylene glycol.
..... I probably shouldn't even jest....
Rgds, D.
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2005 PETERBILT 379 TANDEM AXLE SLEEPER (A56138)
2005 PETERBILT 379...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
