John Deere 401C Hydro trouble
/ John Deere 401C Hydro trouble #41
Local dealer is no big help! That's a pricey housing :eek: I will have to check if housing is good. Thx for replying :)
/ John Deere 401C Hydro trouble #43
I've bypassed it and everything was working like it suppose to. I reconnected it after taking it apart to make sure no dirt was in it. I also plugged the rear selector to take it out of the equation and it's back to the woes again.
/ John Deere 401C Hydro trouble #44
How did the internal parts look? How did the valve fit the bore of the housing? Loose? Tight? Seized? If I were to "throw" parts at it, I would start with the spring, then the internal valve assembly.
Or try and find a used complete valve.
/ John Deere 401C Hydro trouble #45
I found it to be tight when re-inserting and was slipping up & down by gravity at times. There was some wear marks but not really noticeable. Spring length was just a tad short of 4 5/8". There was a third shim which was slightly bigger than the other two. I placed it at the other end against the plug in case it rubbed on the valve. I would have to know if the housing is in good shape before throwing some parts into it. My neighbor has a pressure regulator which I can adapt to it if I choose to go that route.
https://static-assets.imageservice....bout-safety-valve-and-vacuum-relief-valve.png Something similar to this
/ John Deere 401C Hydro trouble #46
If it was my tractor & hyd operated well by bypassing pressure control valve I'd just leave it bypassed. My understanding is pressure control valve is designed to give priority hyd pressure to power steering. Simple solution don't operate any other hyd function while turning steering wheel then hyd problem solved.
/ John Deere 401C Hydro trouble #47
Sounds like a super simple solution and hopefully doesn't causes problems down the road. I'll add a T so I have flow to my rear selector. Adding the mentioned pressure regulating valve will give me peace of mind of not over pressuring the system on my doing. :thumbsup:
/ John Deere 401C Hydro trouble #48
My knowledge of JD "utility tractors" is limited BUT on AG tractors with a similar pressure control valve this PC valve doesn't control system pressure. As I previously stated PC valve provides hyd priority pressure to power steering. The stroke control valve in frt hyd controls system hyd pressure. Does your 401C have a 3 pt hitch??
/ John Deere 401C Hydro trouble #49
Yes, it does have a 3pt hitch! When time permits me to redo the hydraulic routing I'll report back on the findings. Thx again :)
/ John Deere 401C Hydro trouble #50
Isn't 3 pt hitch supplied hyd oil via a galley in trans case supplied by hyd pressure from pressure control valve?
/ John Deere 401C Hydro trouble #51
I have no clue, never seen the internals of the transmission (not yet and crossing the fingers of keeping it that way, lol)
I know the small opening leaks oil into the pressure control valve and the bigger opening doesn't drip back, that's as far as I know.
/ John Deere 401C Hydro trouble #52
Could the small hole of the transmission feed the rear selector is my question?
I'm gonna tap my new pressure regulator into the existing defective pressure regulator to direct over pressure flow and T the working flow towards the rear selector if needed.
/ John Deere 401C Hydro trouble #53
IIRC there is a oil galley where PC valve attaches to trans case that supplies pressure oil to RS housing sealed between trans case & RS housing by a quad ring(T17882)
/ John Deere 401C Hydro trouble #54
That's what I figured and if it isn't, plugs and T fittings will do the trick!
I'll take a pic when I get to it :)
/ John Deere 401C Hydro trouble #55
What parts do you need for it? Looking an JD parts, parts appear to be available, most are O-rings, fittings, the internal valve and spring are available. If the housing is OK, you should be able to get any internal part. The housing is BIG money, but available too. $1625
Can anyone tell me what #5 (dowel pin) is for? There isn't one in mine. I was able to find the parts through another JD dealer. Waiting for calls on used/new parts in the meantime.
/ John Deere 401C Hydro trouble #56
The AG version does not have the pin key 5. It also does not have the cap at the rear key 17. So my guess is the pin is to prevent the internal parts from coming out the front/forward end of the housing, if the fitting for the hydraulic line is removed. Key numbers are for 401c PVC First drawing. Second drawing is for JD 2030 AG tractor PCV
/ John Deere 401C Hydro trouble #57
That makes sense on the different housings usage but I can't find where the dowel pin is inserted. I gather you don't have a FEL on your 2030.
/ John Deere 401C Hydro trouble #58
85bj60;5866816 I gather you don't have a FEL on your 2030.[/QUOTE said:
IIRC Z5's 2030 has a FEL. But whether Z5's 2030 has loader installed or not has no bearing on pressure control valve configuration & related parts or not. All 2030's came from factory with pressure control valve & no FEL attached. Also ag tractors were manufactured with some different parts than industrial tractors.
/ John Deere 401C Hydro trouble #59
My 2030 has JD 245 loader, see my signature. Pressure is connected by a tee after (behind) the PCV. Return is to a ported transmission filter housing.
/ John Deere 401C Hydro trouble #60
Total blindness on my part :confused 3: So a PCV of a 2030 or among others can be fitted on a 401C if I'm reading this correctly. This would greatly increase the odds of finding a used one or a cheaper new one. Also thanks to Zebrafive!
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A61573)
2023 26ft Freedom...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A61572)
2014 Tennant ATLV...
2026 Electric Tricycle (A64194)
2026 Electric...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
