Possible New Attachment
/ Possible New Attachment #41
The guy knows what side of his bread is buttered. Clic bait with his wifes attributes gets more views. Didn't do that early on in the game.
/ Possible New Attachment #42
Excellent information.
So let's assume you want to add 6" of topsoil to 3/4 acre?
43,560 sq ft in an acre. 6" equals 1/2 ft. 43,560 divided by 2 = 21,780 cu ft. 21,780 cu ft divided by 27 = 806 cu yds. 806 cu yds divided by 15 = 54. You need 54 large dump truck loads of dirt moved.
If you had the means to pull a scraper the size of mine it would require 147 trips.
That is doable. Now I need to find a scraper like that! lol I'm in no hurry since this is our getaway and also where the tractor will be kept 1/2 the time so it's fun work to get away from the normal business stuff I do. I definitely don't want to hire the excavator and dump truck combo again though. That is EXPENSIVE. Dump truck is only about $600 a day but the Excavator and operator is far higher and they'd get maybe 25 loads a day moved. I'd spend as much as it would cost to buy my own brand new dump trailer (or used scraper if I can find one)
/ Possible New Attachment #43
Yep..
/ Possible New Attachment #44
That is doable. Now I need to find a scraper like that! -----------------------------
Also called "Dirt Pan": dirt pan - Image Search
They make really small ones too:
/ Possible New Attachment #45
That's cool X. Didn't know they made them that small.
I know this design as a "Clam Shell" scraper. That's the same as mine.
SHOP BUILT  PRESSURE WASHER TRAILER (A67714)
SHOP BUILT...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
KUBOTA MOTOR (INOPERABLE) (A68842)
KUBOTA MOTOR...
PRESSURE WASHER (CONDITION UNKNOWN) (A68842)
PRESSURE WASHER...
2018 HINO 268 4X2 S/A 26FT BOX TRUCK (A69167)
2018 HINO 268 4X2...
