Hinomoto e232 overheating
/ Hinomoto e232 overheating #1
Hinomotoguy
Hinomoto e232
Tractor fan belt broke. When realized it the tractor was running hot. Observed play in waterpump. Replaced waterpump, hoses, and installed new fan belt. Also replaced the fan with its replacement (original had 5 larger blades vs. six smaller blades on replacement fan) which is shown in the Massey Ferguson 210 (some items between the two tractors are interchangable). Still running hot after about 15 minutes of bushhogging. Any ideas?
/ Hinomoto e232 overheating #2
If you are SURE the new water pump is actually moving water your thermostat (if you have one) may be stuck in the closed or nearly closed position. You could also try running the tractor with the front pointed uphill to eliminate air bubbles trapped in the block. Hose out or blow out your radiator fins from back to front to eliminate dust which can prevent cooling air flow.
/ Hinomoto e232 overheating #3
did you top off the coolant after you replaced everything and ran it for a bit?
roadworthy covers the rest.
i have an allis 5020 that has the same engine.
/ Hinomoto e232 overheating #4
I have not seen them advertised in a while, but a product call radiator genie was available. It had 2 long reach wands in the kit. 1 for water and 1 for air.
2001 John Deere 6210 Tractor w/640 Loader LEFT HAND REVERSER (A64047)
2001 John Deere...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
70in Rock Bucket Skid Steer Attachment (A61572)
70in Rock Bucket...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
PULL TYPE DIRT PAN (A63291)
PULL TYPE DIRT PAN...
