How to get out of mud
/ How to get out of mud #2
I found that a large Excavator and a good chain (broke the first two) works well.
/ How to get out of mud #3
At what point did you say "Maybe this wasn't such a good idea, after all!"
If you haven't been there at least once your tractor isn't even broken in. :D
The OP's link could be a good start for the perennial "R1 vs R4 vs Turf" argument. (I don't think thattire tread mattered in his case... he was paunched any way that you look at it.)
/ How to get out of mud #4
Unusually Wet fall, trying to get a job finished and backfilled. Often, you can travel one same path a number of times before you run out of luck. Going up even a slight grade will work against you. It's all math!
/ How to get out of mud #10
NOPE! Just a HORST Walking Axle undercarriage put under an old Dump Box found in the Richie Bothers (Downers and Other Crippled Equipment) Isle.
/ How to get out of mud #14
Yep excavator can save lot time digging out and cussing.
/ How to get out of mud #15
/ How to get out of mud #16
I have found that the absolutely best way to escape being stuck in the mud is to not put the tractor there in the first place. If you walk over your field and your feet get stuck, there is absolutely no reason to bring your tractor out there. Keep it in the barn where it belongs. A prime example would be the first video. Just what in the wide world of sports did he thing he was going to do with a tractor out there?
/ How to get out of mud #18
The comments are turned off must of gotten to many negative ones from k0ua...........
So what would you be doing with a disk out there in the mudhole?
/ How to get out of mud #19
The 80 that weighs 4 times as much could probably drive out there, pull out the tractor and level up the ruts. Tracks make a world of difference.
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2025 Pabreak Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
607 HD PRO CHALLENGER VACUUM PUMP (A60736)
607 HD PRO...
2018 Toyota Tundra Pickup Truck, VIN # 5TFRM5F11JX133691 (A61165)
2018 Toyota Tundra...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
