How to get out of mud
   / How to get out of mud #2
I found that a large Excavator and a good chain (broke the first two) works well.
   / How to get out of mud #3
At what point did you say "Maybe this wasn't such a good idea, after all!"
If you haven't been there at least once your tractor isn't even broken in. :D
The OP's link could be a good start for the perennial "R1 vs R4 vs Turf" argument. (I don't think thattire tread mattered in his case... he was paunched any way that you look at it.)
   / How to get out of mud #4
Unusually Wet fall, trying to get a job finished and backfilled. Often, you can travel one same path a number of times before you run out of luck. Going up even a slight grade will work against you. It's all math!
   / How to get out of mud #5
Did anyone recognize the crop in the field?
   / How to get out of mud #10
NOPE! Just a HORST Walking Axle undercarriage put under an old Dump Box found in the Richie Bothers (Downers and Other Crippled Equipment) Isle.
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
CATERPILLAR 420E BACKHOE (A52707)
CATERPILLAR 420E...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
