6013 vs 7014 vs 7018
/ 6013 vs 7014 vs 7018 #121
Wow, that seems pretty low tech for a couple of birds that can fall out of the sky, but I believe you.
We however, had zero percent success in forming 7075/T6 Aluminum cold and in it's normal state.
And it was not worth the labor cost to try to annealed the material then heat treat it again after forming.
Yes, and forming materials "over two curved wooden blocks" brings back memory's of some weird forming dies for our presses made from varies materials other then steel...
KC
Low tech is what you use when there are no repair parts. You wouldn't believe how we used to repair helicopter blades.
hugs, Brandi
/ 6013 vs 7014 vs 7018 #122
I have 3 gas/welding supply businesses about 65 miles away.
If I can remember correctly you would have to be careful about your bottle purchase because they would only exchange certain specific manufactured bottles?
KC
65 mi one way, wow thats quite the journey just for welding supply's.
I dont about that. My weld supplier guy just brings a bottle when I call, usually the next day or even in the afternoon if I call in the morning, weekdays only, Also if I need welding rods he also brings them, its an auto parts business to so if I need a car part he can bring that........
/ 6013 vs 7014 vs 7018 #123
I have a Dial Arc. At max amps it really needs a 100A circuit hooked to 240V. 480 volts it is half that. On a 50Amp circuit I can get 180-200 Amps w/o tripping the breaker. They are a real power hog. The rectifier throws off a lot of heat energy. I will, up for sale soon as It is too much for what I do now. My little Monkey Ward 230 Amp AC/DC machine does everything I need running on a 50 Amp Circuit.
Back to the OPs original; I have not followed the full, thread. Was there ever much consensus? Like was said early on, it is an individual preference. I worked the pipe trade in my early life. The 7018 came about because ASME and AWS set up standard weld procedures which called out 7018 for the passes after the root which was always 6010. I did a lot of work where we used 6010 all they way. 6010 strength matches A36 pipe strength so some of us saw no reason to use 7018 unless specified. 7018 became popular with pipe welders that like down-hand welding which came from the pipeline part of the trade and it caught on for industrial work also. Down-hand welders swear it runs easier that any of the non-hydrogen coatings. I was always an up-hand guy so I saw no difference. There are upwards of 8-9 low-hy rods. Some have special applications. Lincolns Arc Welding Manual has a good dialog on lo-hy. We never used any 60k rods other than 6010 except when a smooth cap was desired then used 6013 or 6014. Fleetweld 5P (6010) was the go to product.
Ron
My old Miller Dialarc can also be hooked to 480v but I have set for 240v input. 6011 and 6010 can go both directions but 7018 has to go vertical up.
/ 6013 vs 7014 vs 7018 #124
My wood stove grate in the house fell apart this afternoon so I took the one out of the stove in the garage, both stoves are the same, then added a middle brace on then put that one in the house stove, should get me by til the one I ordered shows up. Seem like every two years I have to get a stove grate, maybe 1" thick square stock would last longer.
Then the one that was in the house stove I bubble gummed it back together, the middle like the one in the garage welds terrible but the outer part welds ok for cast iron, I used some scrap steel with 10018 rods, then stuck it in the garage stove. I need to get some cast iron rods but last time I bought nickel rods they was like $2.00/rod
/ 6013 vs 7014 vs 7018 #125
KC, it worked real good! Only when I was welding close to the floor was when my shop got a bit smoky. I was just too far away from the vent hood at that point. I'm thinking to switch the semi-rigid duct to a flexible duct, which would allow me to easily adjust the height at which the vent hood hangs. Also, when not using it, I would be able to just hang the hood up on a hook on the ceiling w/o having to unbolt anything. Right now, I got to remove the entire semi-rigid duct when not using it, and I damage it a little every time I do it.
I filmed some vids of me welding that snowplow under the extractor, but I'm too busy now with work (finally...this 'rona stuff wrecked work for a while) to put them together and edit them so it can be something interesting to watch.
Hey Gene,
Thanks for the update on your welding exhaust system.
I'm sure you will make the necessary adjustments when you have the time to make it better for you.
KC
/ 6013 vs 7014 vs 7018 #126
Yes, but very seldom do we drive the distance for 1 item, usually combine trips with doctors appointments, groceries (curbside pickup at Walmart), etc...
Sometimes we switch things up if we do not have doctors appointments and travel 100 miles north to another Walmart.
We have a Napa in town, about 7 miles away that you can order an item and that they do not have it in stock, they order it and it's usually their the next day by noontime.
KC
/ 6013 vs 7014 vs 7018 #127
hugs, Brandi
Oh, I do not doubt your information, but I'm real glad that I did not know this about 30 years ago while rappelling out of a UH-1N Iroquois.
It's bad enough information when they tell you the helicopter is more important then me and that they will cut the rope if necessary to save the bird...
KC
View attachment 675189 View attachment 675187 View attachment 675188
I like that there stuff, Oldpath.
Hey Gene,
KC
KC, like everything else this here dummy does *points to self*, requires some tinkering.
/ 6013 vs 7014 vs 7018 #130
KC
KC,
Thank you for your service!:m1helmet:
hugs, Brandi
To bad Napa wont do welding gas refils or oxy/acet but since your retired you probably like going for a ride.
Might get the OP upset and most others but lets got to a commercial break. Since your out in the middle of nowhere and I'll never get out there and you are closer then I am, have you ever been to Custer's last stand? It would be one of my first visits since I'm sort of a history buff.
30 years ago I was making weapons of mass destruction and still is.
Herea a picture of you on the rope, does one look down or up, up to see if someone has a knife in their hands...........
View attachment 675247 View attachment 675248
Ha, no way guys, I was born back in the last century still, before the triggered culture took hold. :D
/ 6013 vs 7014 vs 7018 #134
KC,
hugs, Brandi
I second that.
Thanks for the kind works, but my only service was as a civilian SAR (search & rescue team; as co-captain of High angle rescue team, & as captain of swiftwater rescue team) team, and we had trained with the Navy's SAR teams at a couple different NAS (Navel Air Station) Bases.
My draft lottery number was above 300 when I turn 18 years old, so I was not drafted, and I was offered an apprenticeship in the dirty finger nails club of hard work.
Another fact to note is I am left handed and the Navy only allowed rappelling from their helicopter using their equipment and "only right handed" (good thing this was not hard for me).
My praise and continued "thank you for your service" goes out to all that have serviced this great country of the USA, and the ones I have known personally are forever in my memory (RIP) a long with everyone that gave everything for this great country.
I was tired when I posted about my training and probably should of just went to bed before posting as for me to set the record straight needed more information about me that I normally keep pretty closed lip...
Sorry, KC
/ 6013 vs 7014 vs 7018 #135
I myself do not need to go for rides but the wife points me in the direction she wants to go and that's where we go...
Our small town has a welding/fabrication shop for industrial logging/mill and they would allow my bottle gas to travel with their order, but I just don't want to impose.
Your pictures show the winching to or from the helicopter (the one that I trained with was orange & white) which they had a fixed 45 caliber slam charge to sever the cable if necessary and yes there was a knife in a sheath located next to the hard point where the rope was attached to the helicopter.
Yes we have been to the Little Bighorn Battlefield National Monument a couple of times, and we would go again since it's been about 5 years ago.
I believe it's a history hallow ground for both sides involved that the National Park Service explains to the visitors.
It was almost as a similar experience that I had when I visited the Pearl Harbor National Memorial over 40 years ago...
KC
/ 6013 vs 7014 vs 7018 #136
Gene,
Sorry to hijack your welding rod thread, it has really strayed away from your welding rod discussion.
KC
/ 6013 vs 7014 vs 7018 #138
KC
For some reason I'm not picturing logging in MT.... And yeah who wants to bother a fab shop for welding supplies, I did that once to buy steel, they was as cold as cold roll steel, they was into selling labor not steel........
If you have a good camera phone and find your way back down there or anywhere in MT with with scenery, take some pic and post then on this thread>>> https://www.tractorbynet.com/forums...y-pictures-what-does-your-14.html#post5723734
Gene,
KC
No worries KC, that's how we roll on TBN. And civilian search & rescue is legit, man!
/ 6013 vs 7014 vs 7018 #140
Curioscity I git, seems like every Xspert internet welder gold arm says 6013 no good. All kinds of badmouthing 6013, but tons of 6013 made every day, and other than capping pipeline around 2/3 the world must be warehouses filling wid no good rod. I just don't see dat bein a good product line for any factory.
Maybe real welders got no need to be on internet cryin like girls.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
2022 John Deere 5055E (A60462)
2022 John Deere...
