Weight of L3901
   / Weight of L3901 #11
He said his trailer would handle a 5000 lb load. Estimates put the load at or over 6000 lbs. That's not close, it's overweight by an amount very likely to attract scrutiny on an out of state trip.
I asked a simple question, someone suggesting their trailer will handle a certain weight and reality can be 2 different things. My ...guess... is that he has a 7000 lb trailer that weighs 2000 lbs which would put the trailer payload at 5000 plus the ~700 tongue weight. I would not tow that load on that trailer, but it’s why I asked the question.
   / Weight of L3901 #13
I am willing to answer a question using the provided information as a basis for my conclusions. The OP said his trailer would handle 5000 lbs. How much of that 5000 lbs sits on the tires and how much sits on the coupler is unimportant to me. Putting something in the neighborhood of 6000 lbs on it will overload the trailer based on the owner's own description of the trailer's capacity.
   / Weight of L3901 #14
No need to load the tires unless your plowing. Backhoe or heavy ballist is enough for loader. 3 pt ballast is 25% more effective vs loaded tires. If loader is quick attach put bucket in truck bed and drain tires. This puts you 900 pounds less.
   / Weight of L3901 #15
If you didn’t take the backhoe it would be close to working but the whole package will be over 5,000.
   / Weight of L3901 #16
Good feedback here for the OP.
What amazes me is that the dealer could not give you an accurate number on the weight of what he was selling you. I suspect he was able to provide you with an accurate dollar amount of the sale quite easily. :laughing:
   / Weight of L3901
Oh yeah they can get sales numbers without a problem. I just rented trailer. Gonna buy one in the spring if all goes as planned.
   / Weight of L3901 #18
Dealer didn't want to spend the 10 minutes I spent looking for this on the net.
   / Weight of L3901 #19
another source says loader and bucket are only 1000 lbs. So take 200 off of my guess.
Another source (Kubota Canada) says backhoe 77 bare weight 850 lbs. and buckets are from 64 to 104 lbs. so 954 lbs max.
So tractor 2778 (maybe) Loader and bucket 1000, Backhoe 954 and tires (maybe) 600 so 5332 lbs. Its your call.
are you sure those weights arnt in kilos
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2019 GALYEAN...
Rectangle Table (A54816)
Rectangle Table...
2006 APPA TL (A55787)
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
