Weight of L3901
   / Weight of L3901 #1
jmurphy2007
Member
L3901, BX23S
Recently purchased another Kubota, a L3901. Has loaded tires, LA525, BH77 Backhoe. Any guess what weight might be? Have trailer that will handle 5000 lb load. Haven't put on trailer yet and need to move from NH to MA to work a job that BX23S won't handle.
Any help greatly appreciated. Dealer couldn't give me accurate guess.
   / Weight of L3901 #2
Bare tractor. Well you didn't say 2 or 4 or hst.. BUT ASSume 4WD with hydro. 2778 lbs.
Loader.... Guess.. No specs for weight given on website. Should be in supplemental loader install manual. But Guessing 1200 lbs max
Backhoe 77... Guess No specs for weight given. Again just a guess.. about 1500 lbs.
Fluid. Guessing.. 15-19.5 so 30 gallons of something each tire. so about 272 for water each. or about 600 lbs approx depending on what is in them and this is the right tire.
2778 + 1200+1500+600= 6078 lbs... There I took a guess and your trailer is over grossed. best way it to drive it on a junkyard or other scale and find out.
   / Weight of L3901 #3
another source says loader and bucket are only 1000 lbs. So take 200 off of my guess.
Another source (Kubota Canada) says backhoe 77 bare weight 850 lbs. and buckets are from 64 to 104 lbs. so 954 lbs max.
So tractor 2778 (maybe) Loader and bucket 1000, Backhoe 954 and tires (maybe) 600 so 5332 lbs. Its your call.
   / Weight of L3901 #4
I think you are pretty close but I bet the backhoe numbers don't include a subframe kit. Add about 250 lbs if you agree.
   / Weight of L3901 #5
In any case, I think his trailer is a bit small if it is rated at just 5000
   / Weight of L3901
Appreciate the numbers. I'm screwed.
   / Weight of L3901 #7
How did you calculate the trailer load? Did you remove the tongue weight from the load? Still close......
   / Weight of L3901 #9
He said his trailer would handle a 5000 lb load. Estimates put the load at or over 6000 lbs. That's not close, it's overweight by an amount very likely to attract scrutiny on an out of state trip.
   / Weight of L3901
I don't want to take a chance. Sunbelt rentals has a 18ft trailer that will handle 6900lbs. $135 a day....or I tell the wife I need to buy a new trailer, hmmmm
1980 Gleaner F2 with heads (A55315)
1980 Gleaner F2...
pressure washer (A55973)
pressure washer...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
