MT3 57 Delivered
/ MT3 57 Delivered #1
PCABE5
Wisconsin
John Deere 4066R Cab and loader
My MT3 57 was delivered yesterday. Haven't had time to really look it over but seems pretty nice.
As I get more time I'll be able to give some more feedback.
/ MT3 57 Delivered #2
:thumbsup::cool2:
CONGRATS!! Love that spot for the back up camera too. Is it mounted to the glass??
/ MT3 57 Delivered #3
Do you plan to move snow with it? Do you plan to groove/stud/chain the tires?
/ MT3 57 Delivered #4
Yeah, I believe the display mount is stuck to the glass. Really good placement if you ask me...out of the way and visible. Can still use the right hand door.
Congrats!!!
/ MT3 57 Delivered
:cool2:
Yes there is an adhesive mount stuck to the glass.
Snow removal, mowing, brush hogging, you name it and it'll be used for it.
The plan is to grove the tires like I did on my old one. It does make a difference in traction.
/ MT3 57 Delivered
For the floppy bucket guys the new loader uses 1/4" inch hoses and 3/8 hard lines. Smallest lines I've ever seen on a loader so I'll be curious what the cycle times are.
/ MT3 57 Delivered #7
Yeah, figured thats how they "fixed" the loader. Smaller lines means lower flow. Just like installing a flow restrictor. But even with the flow restrictor I installed, I still have the issue at the lower RPM ranges.
I know you just got your new tractor, but have you run your hydraulic pressure tests yet? Curious to see how they stack up with the results you got from the your XR after the new pump.
/ MT3 57 Delivered
I haven't run a flow test on it yet but I certainly could. If I get time this weekend I'll hook up the meter. Same pump so I would expect the same or very similar results. I kept the larger pump off the old one but with the smaller lines I'd be worried about the flow restriction on the loader.
The loader mounts I believe are different than yours and maybe that was to eliminate the tire rub.
/ MT3 57 Delivered #11
Thats weird. See attached. Thats what I get when I click that link.
/ MT3 57 Delivered
Wondering if it's because I'm uploading via Tapatalk? It was there earlier. I'll try it again.PXL_20201028_210223824.jpg
/ MT3 57 Delivered #14
Yeah, that fixed it.
I'll have to take a look at mine again to compare. Hopefully they got that fixed. Thanks for posting.
/ MT3 57 Delivered #15
How did you groove the tires? what pattern?
/ MT3 57 Delivered #16
I'd be interested in your feedback on the camera display update frequency. The one I put in is a little slow which makes the picture a little choppy and delayed when moving. Really clear when the tractor is stationary. I mounted mine to the front wiper cover bolts.
/ MT3 57 Delivered #17
View attachment 674603View attachment 674604View attachment 674605
Like mine, it looks like your dealer didn't remove the plastic from the seat either. Thought that would be part of getting the tractor ready for delivery. I also had way too much air pressure in the tires but they blamed that on the new guy they just hired. Since my dealer also installed the loader I did a pretty close inspection of that installation too. Must have spent over 3 hrs. looking over the entire tractor to figure out where everything is - I even read the owner's manual!
/ MT3 57 Delivered
The refresh rate was fine. I noticed no issues with movement or stationary.
I don't think they removed it so someone didn't sit in the seat with grease on their pants. I don't think I've ever bought a tractor that had air pressures adjusted. They are usually maxed for shipping purposes.
/ MT3 57 Delivered #20
I have such tire iron after grooving my tires too. It adds a little more traction on snow when it is 32F and lower. I have such a steep driveway I end up chaining up all 4 tires anyway.
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
72in Bucket Skid Steer Attachment (A61572)
72in Bucket Skid...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A61572)
2014 Kawasaki 70Z7...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
2011 FREIGHTLINER M2 112 CNG  6X4 T/A DAYCAB TRACTOR (A59912)
2011 FREIGHTLINER...
