LS MT3 57 Regens TO Often
/ LS MT3 57 Regens TO Often #1
KCTractors
Central Wi
LS MT357, Case 530 CK, , Ford 2000, , Ford 8N, Moline 602
I traded a MT3 42 for a MT3 57 back in February 24. I a have sixteen hours on the 57 now and it regened already four times. Always does it when I am ready to put it away, so it's another twenty-five minutes of running the engine at 2,200 rpms before it gets done regenning.
The MT3 42 that I traded had 127 hours on it and it regened twice in that 127 hours. Son-IN-Law has a MT3 57 also and it regens every few hours to. I called the Dealer, they told me to watch it for awhile yet.
If this is going to continue, I will be looking for a older Ford tractor with a cab. I am using more fuel for regenning than actually working and yes, I am running the tractor over 2000 rpms when using it and not much idling.
/ LS MT3 57 Regens TO Often #2
Sounds like it might be a plugged up DPF or bad sensor. I cannot imagine it being plugged after 16 hours though. It could be a faulty DPF DIFF-Pressure sensor that measures the pressure difference between the front section and rear section of the DPF. It essentially senses if the DPF is getting plugged up, and the ECU preforms a regen cycle.
If the filter was plugged, you should get a fault code.
The dealer saying to wait see what happens, is just kicking the can down the road. I'd look for a different dealer. This tractor, as I'm sure you know, regens about every 50 hours. Regenerating every 4 hours is not ok. This should be under warranty, and should be 100% covered. Blow up your dealers phone.
/ LS MT3 57 Regens TO Often #3
welcome to the unlucky club.
/ LS MT3 57 Regens TO Often #4
John Deere released a video that said to run DPF tractors as normal. Do not constantly run them at higher rpm thinking it will burn cleaner. If the tractor isn’t working when at higher RPM it is actually causing more soot needing to be cleaned by the DPF filter.
It’s worth an experiment anyway, to try reducing rpm’s.
I just got my MT3 42, but am determined to try running it like my non DPF tractor and see where it leads me.
/ LS MT3 57 Regens TO Often #5
Welcome to the club there are several threads about LS tractors regen problems.
Mine regens every 12 hours with an occasional 14 hours depending how hard I run it..
I think I will try running it like a normal tractor, can not get worse.
/ LS MT3 57 Regens TO Often #7
Sounds to me like 2 distinct issues. First is a failed or malfunctioning sensor and Two, an ill equipped (to diagnose the issue) dealer. You need to contact another dealer, one that has the expertise to diagnose the issue and remember, ALL emissions controls are guaranteed for 5 years per gummit mandate.
/ LS MT3 57 Regens TO Often #8
You gotta run the cleanest best Over The Road diesel you can find. The reason for Regen is to clean off the soot accumulated from running the engine. If you're regening often that means the fuel is of poor quality and the sensors tell the engine go into regen.
After the first issue we had with regen it was because I cheaped out and went to some local gas station got diesel and immediately had issues. Went back to the OTR diesel and problems solved. I get diesel and the local TA truck stop. My tractor goes 100 ish hours before regen.
Also dont run summer diesel during the winter time.
/ LS MT3 57 Regens TO Often #9
I only buy off road diesel for my equipment but I buy it at a local volume station where all my farmer friends buy theirs as well but I still add biocide in the summer and PS silver label in the winter. I'd say the main reason why I never have fuel issues is the Racor fuel polishing filter with 2 micron pass elements I have on all my diesel powered equipment. The Racor filters out everything and you can conveniently drain any contaminates with the built in bowl drain. Far as I'm concerned, it's a very worthwhile investment. Since installing them, I've had zero fuel issues.
/ LS MT3 57 Regens TO Often #10
There is NO difference between on road and off road ULSD diesel except the red dye in ORD. So long as you buy from a retailer that turns volume, it is a non issue. I don't pay road use tax on my diesel and never will and if I did get some bad fuel, my Racor will handle that chore quite nicely.
/ LS MT3 57 Regens TO Often #11
Racor's are NOT a cheap date though I do use Chinese knock off bases (IFJF to be exact) which are about half the cost of a genuine Racor base and are threaded in SAE to accept genuine Racor filters. I only run genuine Racor filters in the 2 micron pass as well as Racor bowls. You'll pay around 26 bucks for a genuine Racor 2 micron pass filter which is around 10 times better filtering efficiency that the OEM spin on fuel filter or the clear bowl filter on smaller tractors which are usually 20 micron pass. I've actually bypassed bot the spin on filters and the bowl filters on both my Kubota's. They are not needed with a Racor 2 micron pass, 100% water shedding filter.
/ LS MT3 57 Regens TO Often #12
The problem is that LS the company, not the dealer, says if a regen happens more than 2 hours from the last, that is an expected behavior. Call when it happens in less than 2 hours.
That is not a correct all encompassing statement, but regardless, at one point my dealer said the same thing, so I told them to test it and prove it. They were unable to do that.
/ LS MT3 57 Regens TO Often #13
My 573 has regenerated about 14 times in 300 hours. I’ve tried running higher Rpms with not much load and I’ve tried lower Rpms. On my tractor it does seem to make a little difference. Seemed the regens were further apart. Closest was about 12 hours. Each one only last about 18 minutes.
/ LS MT3 57 Regens TO Often #14
I have the same experience as the last post but with a MT3 57. Not as many hours on tractor but the regens are anywhere from 13 - 20 hours with about the same time during regen. I'm usually in the middle of a job when it happens so it is not a big deal to me since I can keep working (I thought when I was looking at a Branson tractor it had to be parked when regen occurred). I usually keep the revs above 2000 so I can't comment if it would be worse if I ran it like an old school tractor.
/ LS MT3 57 Regens TO Often #15
Yeah I should add to my comment , mine has been fine with regen. If I work it hard it only does a factory regen at every 50 hours. So plowing and tilling it will go 50 hours. Doing driveways and spreading stone etc , piddly stuff it usually regens between 12-23 hours.
/ LS MT3 57 Regens TO Often #16
This is how I have been running my M7060, working fine for me so far at almost 400 hours. It does not seem to matter how I run it regens happen about the same time.
/ LS MT3 57 Regens TO Often #17
Not meant as "all encompassing", I'm passing on my experience with my tractor. Ask a pro trucker if quality of fuel matters.
You can test it yourself. Go to your local gas station and fuel up with their diesel. When your tractor starts going into regen, there's your test result. I did it... never again.
/ LS MT3 57 Regens TO Often #18
I found mine is almost he same. Plowing snow or dragging the transplanter relatively easy work, 1800/2000 rpm the re-gen indicator would flash, but then no re-gen. Then around 30/40-ish hours, re-gen.
Now, tilling, pulling the cultavator deep, undercutter or sub-soiling in the 2000 rpm range works the engine a little more at a little higher, steadier temperature leads to a full 50 hours before regen cycle with my XR3140. Basically, the harder work will get it to the 50 hr regen way more consistently.
I believe its engine temperature related. Maintaining the constant higher temperature of the engine working at a higher load burns cleaner, compared to an engine doing a lighter load of work. I also keep a clean air filter and buy fuel from a high volume distributor and add anti-gel, cetane boost and lube additive to my fuel.
Somewhere here on tbn, I read that someone had partially blocked the radiator on there LS to create more heat in an effort to keep from regen cycling every hour or what ever it was and it worked, Got more run time before regen.
/ LS MT3 57 Regens TO Often #19
I have an MT3 57 with about 400 hours on it. This is what I have found.... running at over 2,000 hours all the time doesn't help anything. It may actually make things worse. Also, give it some time. When I first got mine, it did a regen about every 15 or 20 hours.. which was fine with me. Then, at about 150 hours, it started doing a regen every 5 hours. And... one time it even did a regen, then 10 minutes after it was done, did another one!!! I thought for sure there was a problem.. but the service manager at my dealer said to just keep using it and it should sort itself out. Well, he was right. The regen's started getting further and further apart, and now it's back to doing it about every 20 hours. Bottom line, I think it varies depending on different variables, notably fuel quality, outside air temp, humidity, etc. I think they are all factors. My last regen was about 30 hours ago. Give it some time, I bet it will be fine. Logic would say that it would regen consistently.. but it doesnt. It varies widely. Don't worry about it.
/ LS MT3 57 Regens TO Often #20
I am surprised that some here are experiencing no difference in regen frequency between running at higher rpms and idling. I track the regens on my Kubota, and I definitely see more frequent regens with excessive idling, but my overall overage during 900 hours is a regen every 50 hours.
As has been mentioned, the type of tractor work certainly plays a role. I just ran my brush hog doing a stream bank for about 2 hours, and the DPF % went from 75% to 54%.
