John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,816
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I found the thread with LouNY's description of the drive-on chain method: Mounting Tire Chains.
To recap his first post in that thread:
As I noted in post 37 of that thread, after 2 years of installing chains the hard way, I switched to driving them on, I can get my chains on in about 15 minutes a tire (and that includes dragging them out of storage and laying them out on the ground). If I put them on and off more regularly, I'm sure I could do it faster.
The one difference from Lou's method is, I tie to the center of one of the cross chains, rather than to the side chains. I find this works easier, since I can leave the string on, and it leaves the side chains free to make the connections. The string comes off after the chain connections are made.
On a friend's tractor with not much tread left, I run the string through one of the holes in the rim, instead of hooking it over the tread. I've not installed chains on large turf tires, but I suspect the string through the hole in the rim would be the way to go on that type of tire as well.
The rest of that thread is worth reading through: there are some other good tips and experiences mentioned.
I put chains on one tractor yesterday, there are lots of ways to mount chains I thought I would share the easiest way I have found to do so.
1) lay the chains out with the outside, the ground contact side facing up
2) tie a short cord to the side chains, the length will depend on your tire size, on mine I end up with a V shape about 3 feet.
3) back up to your chain, take the cord and hang it on the tire treads.
4) drive forward slowly, stopping to spread the chain out on your tire.
5) continue doing this till you have rolled the chain up on the tire and have working room at the rear of the tire
6) your chain should be well centered on your tire and have very little slack.
7) fasten your chains.
8) step back and check out your work
