BX choices
/ BX choices #1
Lilguy
Chicago, Illinois
Kubota
In a earlier post you all help me out with a suspect 2380. I told the owner that unit is not going to me. To many negative out of the box.
I asked if he wanted to call it a day or try something else, itç—´ up to him.
He said he has a 1888 and a 2680 in crates and would either of those work? He offered that they were all basically the same except for engine horse power. His salesman offered back at the beginning that even though all 3
use the same frt loader he would not recommend a quick detach bucket on the 1880 because itç—´ farther forward than the pinned bucket, risking some stability issues. The owner did not agree with that conclusion.
I said talk to your salesman again and let me
know If youæ±*e willing to proceed. I also said I obviously will not commit to something I haven稚 test driven. Prep it, let me drive it and We値l go from there. They値l get back to me next week.
I知 trading in a B2601 FLBHMMM thats to big for our new property.
Want the loader for snow and dirt, mower for 2/3 acre of grass. Thanks
/ BX choices #2
SSQA is just one weight for all tractors: ~110 pounds. SSQA attached bucket does protrude a little forward of pin on bucket.
Combination of SSQA coupler weight and protrusion of coupler reduces modest BX Loader lift capacity.
LA344 Pin-on lift capacity at pins = 739 pounds
LA344 SSQA lift capacity at pins = 613 pounds
Don't you have the Kubota BX brochure??
BX VIDEO: Is the Kubota BX188 enough tractor for you? - YouTube
/ BX choices #3
SSQA only unless one knows for 100% they will never use FEL for anything but bucket and then still get SSQA for the next owner if it be a new buyer or heir. SSQA only!!!!!:2cents:
/ BX choices #4
I asked if he wanted to call it a day or try something else, it逞エ up to him.
use the same frt loader he would not recommend a quick detach bucket on the 1880 because it逞エ farther forward than the pinned bucket, risking some stability issues. The owner did not agree with that conclusion.
know If you豎*e willing to proceed. I also said I obviously will not commit to something I haven遞 test driven. Prep it, let me drive it and We蛟、l go from there. They蛟、l get back to me next week.
I遏・ trading in a B2601 FLBHMMM thats to big for our new property.
Your trading in a B2601 because it is to large? In what way?
Let me place the numbers side by side for you.....
Your BX is a half inch longer.
BX is 3.9" narrower.
BX is 1.9" lower at the ROPS.
BX has 4.4" less clearance under the front axle.
BX is 111 lbs lighter (bare tractor weights)
BX loader is 330 lbs less loader lift.
BX lifts 7.5" less height.
BX bucket break-out force is 620 lbs less.
Going to the BX is not saving you much at all in size, but it sure costs you a lot in performance! And when you trade that thing in, your going to want to bring a tub of Vaseline with you. You'll know what to do with that as the deal forms.
/ BX choices #5
If you're adamant on a BX, you'll never go wrong with a little more HP.
Fortunately you didn't bring home the BX that couldn't seem to have the "coasting" problem adjusted out of it. A couple of adjustments and lubing the pedal took all of the problem out of mine in forward and quite a lot of it out in reverse.
/ BX choices #6
Your trading in a B2601 because it is too large?
Excellent advice. Keep the B2601.
/ BX choices
I bought the 2601 set up to take care of 16 acres and put in a Koi pond. A year later a neighbor offered to buy us out at a premium
and we moved. Now .9 acre. Want a bucket to
move dirt and snow. A deck to mow and diesel
for safety sake and longevity. Whats thought on the 1880?
/ BX choices #9
^^ Exactly. You will quickly forget about the little bit of lift capacity but always appreciate the convenience (as someone who just moved to a SSQA tractor) .
Good luck.
/ BX choices #10
The only disadvantage to your B model over the BX is cutting the 2/3 ac. In every other scenario the B is an advantage. For 2/3 ac, I'd be looking at a dedicated ZTR that will probably cost as much as you are going to lose on a trade. If the 2/3 ac is open land (not a lot of trees and other curvy landscaping), the B should work just fine. If I had to give up my BX or my B, the BX would easily be the first to go.
/ BX choices
I have the SSQA material bucket on it now. Backhoe with 12“ bucket and a 60 inch deck. Takes up a spot in the garage, buckles the flag stone paths around home. The 54 inch deck would fit around obstacles better.
want diesel for safety and longevity.
Haven’t used it to mow since we moved here. Moved snow a couple times and move bags of stuff here to there. Old dive way was 1300 feet, new one 80. 5+ acres then, 2/3s now with many more tight places. Not gonna be running anything off the pto, sold box scraper, grader blade, snow blower, log splitter, post driver and rear pallet lift with L2250 when moving. I think I’m leaning 1880.
/ BX choices #12
Sounds like you've got a plan and your working it. I'm sure you'll be pleased with the baby B series.
/ BX choices #13
I agree. The cost to trade a bit to large machine could be a bit hard to swallow but it's your money. You could keep the B and probably buy a box store riding mower for the difference you'll lose and have two machines and dedicated mowers are better for mowing than multi purpose machines. Consider maybe adding a used Kubota ZTR to yur B stable and have the best of both worlds.
/ BX choices
The deal i'm being offered.
$16000.00 trade in value B2601 TLBMMM.
All BXs with Quick detach FL and BBox
and MMM.
1880 with $1800.00 back
2380 with $200.00 back/ not available
2680 and $1500.00 additional.
so far.
/ BX choices #15
and MMM.
so far.
Go here Kubota | Finance - Promotions & Special Offers and Build both machines and see MSRP for both machines and see how much difference it is costing you to make the trade. I know the actual sales price should be 15% to 20% less than MSRP but your just seeing the difference between machines and then allow or see how much your paying for your hours of usage of your B.
You could probably sell the Back hoe and get enough to get a decent ZTR or see if the dealer will trade a small Kubota gas ZTR for your backhoe or call Barlows and see how they will trade all combinations.
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
CASE 105C (A62177)
CASE 105C (A62177)
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
