Chains....Age old question...need some advice
/ Chains....Age old question...need some advice #1
River19
NH/ NEK VT
Kubota B2601
As I have mentioned elsewhere on the site, I have a Kubota B2601 on order (as do many) and one of its primary duties will be snow removal on my 500' gravel driveway in NH with a serious grade up to the road with the 48" commercial blower.
I am going with Turf tires in 33 12.5 15 as non winter duties will require a lot of lawn traversing hence turf........I really want a nice cross pattern like a Duo-grip with the v-bar "picks" for icy conditions.......I am fine paying for quality to an extent....that being said I don't want to pay on the north side of $500 if I can avoid it......
I have spent several days researching and pricing etc. and have reached analysis paralysis and while I don't like to ask for help......I NEED HELP :)
Any recommendations that fit that description?
Thanks
Steve
/ Chains....Age old question...need some advice #2
The only advice I'd give is to get hardened steel chains. They are not the cheapest but they should stay a long way from your $500 price point.
/ Chains....Age old question...need some advice #3
Double check to see if you have clearance with turfs+chains.
/ Chains....Age old question...need some advice #4
I've had luck with buying or getting for free brand new chains from cars back in the 60's and 70's... the ones with the 15 inch tires like Oldsmobile, Cad, etc...
They are easy to cobble together and so far not a single failure...
It might take 3 or 4 to make a size to fit a Kubota CUT.
Cold Chisel on the anvil or bolt cutters and then split link to the size needed.
The rubber tensioners work wonders... double or triple up on them...
I got wheel spacers being installed before delivery so hopefully should be good to go.......but I appreciate the "heads up".....
Right now the leader in the clubhouse seems to be a 2 link V-Bar from tirechain.com.....for ~$400/pair......
/ Chains....Age old question...need some advice #6
Do you need to operate on side-hills, or is most of your winter work straight up and down the hill?
I started off with 4-link V-bar, ladder-style chains on my rear tires (R4). It worked fine for going up and down my driveway, but lateral traction left a good bit to be desired. Because of that, they were not good to use on rough terrain or in the woods: I found myself sliding sideways, always at the worst times.
I switched to duo-grip chains with V-bars. These greatly improved the traction on side-hills and worked well both clearing snow from my driveway and working on rough terrain in the woods. However, the ride at even moderate speeds on hard ground felt like it was going to shake me (and the tractor) to pieces. Since I regularly need to drive the tractor some distance over the roads, the Duo-grip chains were just not an option for me. (I have filed rear tires. I've often wondered if it might have been acceptable with an air-filled tires, particularly air-filled Turf tires, which are more flexible than R4s.)
I ended up with the "euro-style" studded chains (OFA EKO 8, there are similar chains made by other manufacturers). Good forward and lateral traction, and great both off road and over the road. They nly downside is that they are more expensive than the other styles.
/ Chains....Age old question...need some advice #7
I ran V-bar ladder chains on my Ford 1700 4WD. All four wheels chained up. More than adequate traction for winter snow plowing. The two sets of chains were $480 total. Only down side - the chains were TRUE tractor chains. The rear chains were extremely heavy and a PITA to instal.
/ Chains....Age old question...need some advice #8
I have exactly the same conditions as you with same size tractor and also in NH. I got euro style OFA EKO 8 chains just down the road in Tamworth, NH. I also got same style but smaller/lighter for the front.
Windy Ridge Corporation Since 1985
Good people to deal with and no shipping cost for pick-up. No slipping whatsoever with these chains, and I am plowing snow with a 7' rear blade, putting a lot more pressure to cause slipping. You can Google a video showing how to install them by letting the tractor do most of the work.
I have seen people recommend these guys elsewhere.....would love to chat with them.....their site seems like a business to business company, is there someone specific to contact there? I'll have to look into them more as I would love to shop local....and pick up is no problem.
/ Chains....Age old question...need some advice #10
The last paragraph up there is what you need;
excellent traction, side grip, and a quality ride.
They will ride almost as smooth as not having chains on.
I have used 2 link and 4 link space v-bar and street chains and even old double ring chains the Euro style will beat all of the others hands down.
If you look for installation pictures and videos you can find some of just driving the chains on this is the easiest way to mount most any chain.
/ Chains....Age old question...need some advice #11
Just give them a call. It's a big warehouse and they will take you in, grab the chains with a forklift load them into your vehicle.
/ Chains....Age old question...need some advice #12
I have studded chains similar to the OFA and Aquiline Talon chains. You are going to pay more up front for them but they are worth it. I only run chains on the rear tires and have plenty of steep hills I go up. They are still holding up well after 10 years of use. As long as you've got the clearance it's what I would recommend. I have V bar type chains on my dually dump truck and the V's wore out pretty quickly turning them into just chains. IMO this is one of those pay once now or pay more in the long run when you are forced to replace them much sooner.
Thanks for the suggestion as well............what is the difference between studded and v-bar? Intuitively I can assume the chain links might have studs vs. the extra "V" spike on the v-bar.......I seem to see more v-bar and "regular" chain offerings vs. "studded".
I'm thinking since my chains will never see pavement I shouldn't have excessive wear on whatever I choose to go with.
/ Chains....Age old question...need some advice #14
If I found that chains were needed here. I'd definitely consider purchasing studded chains - something like the Aquiline Talons or similar.
Experience with heavy tractor V-bar chains was very positive. But they are so VERY heavy and my experience shows they are tough to instal. I would hope that studded chains give adequate traction and are somewhat lighter.
Thankfully - with the larger, heavier tractor I've never needed chains.
/ Chains....Age old question...need some advice #15
The Euro style studded chain puts a continuous pattern down on the ground with the studs providing the maximum traction,
the Euro style can be found without the studs but are seldom seen or used.
quickhitch.jpg chains 8.jpg 100_4167.JPG Branson chains.jpg IH 574 chains.jpg Oliver chains 2.JPG 100_4165.JPG
The continuous chain pattern running around the tire with the studs takes the bounce and rough ride out of the chains.
n the picture of the Oliver with two link spacing every other cross chain is a v bar reinforced and the others are just a street twist link,
these were a combination of two different sets I had bought just twisted links first as they were much cheaper.
I got what I paid for, so then I bought the set of bar reinforced which did provide more traction but not a real lot more.
I then combined the two sets to make a set with two link spacing and it was better then previously.
The Euro style on the 574 were the first set of them that I purchased, the difference in traction was unbelievable.
After seeing the difference my brother over on the farm ended up getting several sets for the tractors we feed with in the winter.
The Branson has two different brands of the Euro chains after the first winter with her I very seldom mount the front ones any more,
if a major ice storm is forecast I do throw them on.
This style of chain provides the best traction combined with the smothest ride on pavement or frozen ground of any chain I have used.
/ Chains....Age old question...need some advice #16
That's good to hear LouNY. It's for sure - V-bar ladder chains are NOT the best ride - - anywhere. Maybe they are OK on very soft ground or muddy conditions. On hard or frozen ground - they can shake the fillings out of your teeth.
/ Chains....Age old question...need some advice #17
Back in the 50's and 60's we had some double ring chains, the cross links were double rings about 2 1/2" in diameter they worked great in deep snow and mud,
but when you got on hard ground it was driving at not much faster then a walk or they would bounce and jar you right out of the seat.
/ Chains....Age old question...need some advice #18
If you think ladder chains are a rough ride, try duo-grip style chains on filled rear tires (the fill takes some of the flex out of the tires, since there is much less air space to allow for compression). I could tolerate my 4-link V-bar ladder chains in high gear on a paved road. That same gear was completely intolerable with V-bar duo-grips.
/ Chains....Age old question...need some advice #19
Lou is right about the installation method: driving the chains on is a quick, easy way to get them on properly. I've used it with my ladder chains, my duo-grips, and now my OFA EKO 8 chains (aka "Euro style" similar to Aqualine Talons or Trygg ice chains). I normally don't need to go back and retension the chains after a bit of driving, as I did with other installation methods (with the OFA EKO 8 chains, they recommend leaving some slack in the chain anyway, so I never need to retension, unless I put them on too tight the first time.) I've posted a description of the drive-on process on here somewhere, and someone else posted an even better description (I'm thinking it was LouNY, but it was a while ago, and I may be remembering incorrectly.) I can usually make it through the installation of a pair of rear chains without any swearing using this process. Before I learned it, installation took much longer and was basically a curse-fest.
I got my OFA EKO 8 chains from Reed Supply in St Johnsbury, VT. Great people to deal with. Delivery to one of the regular stops on their route in a town just 5 miles away from me was just $15. I've also heard good things about Windy Ridge that MAD777 mentioned.
BTW: for an interesting comparison of chains types and their suitability for various tasks and conditions, see this chart. The "Euro-style" chains that I and others have been raving about are referred to as either "studded high strength alloy": Tractor Tire Chains Comparisons. Really, the only rated weak spot is on bare pavement - but since all I'm doing is transporting when on bare pavement, I'm not worried about that. When I've pulled out a stuck vehicle, it worked great on ice-covered pavement when the Ice was frozen hard to the pavement. The only time I had trouble was when the ice had started melting off: I spun the ice out and was on bare pavement. I had to find a patch of dirt or something that the chains could get a solid bite on.
1993 GMC Sierra Pickup Truck, VIN # 2GTEK19K7P1534489 (A65563)
1993 GMC Sierra...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
3ft Metal Chevrolet Tailgate (A65583)
3ft Metal...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
