3015H rear Ballast weight?
/ 3015H rear Ballast weight? #1
cpita
Midland, Tx
Branson 3015H & Farm Pro 2425
I have a 3015H with a FEL, and would like to add a homemade ballast weight in the back. The lift is rated for 3306 lbs at the ends & 2420 at 24” I was thinking of either using a 55 gallon barrel which would be over 1000# or a 30 gallon barrel which would be about 600# which one should I go with?
/ 3015H rear Ballast weight? #2
Branson 3015H - attachments
2016 - 15 Series
Compact Utility tractor
Loader type: Branson SL15
Height (to pin): 98.4 inches [249 cm]
Clearance, dumped bucket: 79.1 inches [200 cm]
Dump reach: 28.1 inches [71 cm]
Dump angle: 48
Reach at ground: 62.2 inches [157 cm]
Rollback angle: 36
Breakout force (at pin): 3456 lbs [1567 kg]
Lift to full height (at pin): 1835 lbs [832 kg]
Dimensions:
Weight: 3014 lbs [1367 kg]
Wheelbase: 65.8 inches [167 cm]
Length: 118 inches [299 cm]
Width: 57 inches [144 cm]
Height (ROPS): 94 inches [238 cm]
60 inches [152 cm] *
Ground clearance: 12 inches [30 cm]
Page information:
Last update: June 24, 2016
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
/ 3015H rear Ballast weight? #3
600 pounds of TPH counterbalance should suffice for 90% of your FEL lifts with air inflated rear tires.
With tractor in 2-WD, equipped with R4/industrial tires and bucket empty, your tractor should not mark lawn. (At least in north Florida.)
600 pounds of TPH counterbalance should suffice for 100% of your FEL lifts with 'loaded' rear tires.
I suggest searching for a 600+ pound Box Blade or a 600+ pound rototiller as counterbalance. Both implements are usually available used at reasonable prices.
1,000 pounds of TPH counterbalance will be ample for 100% of your FEL lifts with air inflated rear tires.
Your Branson has tremendous FEL lift capacity for a 3,000 pound bare weight tractor. If you have stability issues, consider having the rear wheels spread further apart.
/ 3015H rear Ballast weight? #4
What material were you intending on using for your ballast?
/ 3015H rear Ballast weight? #5
I would want to go at least half your rated 3 pt lift capacity in ballast weight.
That would cover you for most things.
/ 3015H rear Ballast weight? #6
Keep in mind the foot-lbs relationship. It's a mathematical product so you can go for heavy close in or light far out and get the same result.....meaning something like a 6' shredder would be all you would need; a 5' if you are not working max FEL loads.
I have a 5 shredder that came with it (which works good for compensating the weight) but due to hanging out excessively on my trailer when transporting, is why I’m wanting a ballast
/ 3015H rear Ballast weight? #9
I just leave the BH on... No issues so far
Parden my lack of knowledge, but what does TPH stand for?
/ 3015H rear Ballast weight? #12
I have a 3015R. For ballast I have a 55 gallon barrel 85% full of concrete with part of an old differential and assorted random chunks of steel for an estimated ~1300 pounds. So far I have picked up some rather large pieces of hickory trunk with it and was completely stable. As is a bucket FULL of moist dirt. I have some 24"ID by 8' concrete pipes to move, they are about 2200 lbs. I am interested to see how my ballast does with that, I am pretty sure the tractor will pick it up. These pipes are the first thing I have had the opportunity to move that I have a pretty exact idea on weight. My goal is to lift them high enough to get them on a trailer. I'll let you know how it goes.
2025 ELECTRIC GOLF CART (A61569)
2025 ELECTRIC GOLF...
Misc. Jack Stands & Elite Round Bar Kit (A62177)
Misc. Jack Stands...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
2022 Mack Granite Dump Truck, VIN # 1M2GR2GC0NM025993 (A61165)
2022 Mack Granite...
Gehl RS5-19 (A62177)
Ford Tailgate Themed Wall Decoration (A61569)
Ford Tailgate...
