3015H rear Ballast weight?
/ 3015H rear Ballast weight? #1
cpita
Midland, Tx
Branson 3015H & Farm Pro 2425
I have a 3015H with a FEL, and would like to add a homemade ballast weight in the back. The lift is rated for 3306 lbs at the ends & 2420 at 24” I was thinking of either using a 55 gallon barrel which would be over 1000# or a 30 gallon barrel which would be about 600# which one should I go with?
/ 3015H rear Ballast weight? #2
Branson 3015H - attachments
2016 - 15 Series
Compact Utility tractor
Loader type: Branson SL15
Height (to pin): 98.4 inches [249 cm]
Clearance, dumped bucket: 79.1 inches [200 cm]
Dump reach: 28.1 inches [71 cm]
Dump angle: 48
Reach at ground: 62.2 inches [157 cm]
Rollback angle: 36
Breakout force (at pin): 3456 lbs [1567 kg]
Lift to full height (at pin): 1835 lbs [832 kg]
Dimensions:
Weight: 3014 lbs [1367 kg]
Wheelbase: 65.8 inches [167 cm]
Length: 118 inches [299 cm]
Width: 57 inches [144 cm]
Height (ROPS): 94 inches [238 cm]
60 inches [152 cm] *
Ground clearance: 12 inches [30 cm]
Page information:
Last update: June 24, 2016
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
/ 3015H rear Ballast weight? #3
600 pounds of TPH counterbalance should suffice for 90% of your FEL lifts with air inflated rear tires.
With tractor in 2-WD, equipped with R4/industrial tires and bucket empty, your tractor should not mark lawn. (At least in north Florida.)
600 pounds of TPH counterbalance should suffice for 100% of your FEL lifts with 'loaded' rear tires.
I suggest searching for a 600+ pound Box Blade or a 600+ pound rototiller as counterbalance. Both implements are usually available used at reasonable prices.
1,000 pounds of TPH counterbalance will be ample for 100% of your FEL lifts with air inflated rear tires.
Your Branson has tremendous FEL lift capacity for a 3,000 pound bare weight tractor. If you have stability issues, consider having the rear wheels spread further apart.
/ 3015H rear Ballast weight? #4
What material were you intending on using for your ballast?
/ 3015H rear Ballast weight? #5
I would want to go at least half your rated 3 pt lift capacity in ballast weight.
That would cover you for most things.
/ 3015H rear Ballast weight? #6
Keep in mind the foot-lbs relationship. It's a mathematical product so you can go for heavy close in or light far out and get the same result.....meaning something like a 6' shredder would be all you would need; a 5' if you are not working max FEL loads.
I have a 5 shredder that came with it (which works good for compensating the weight) but due to hanging out excessively on my trailer when transporting, is why I’m wanting a ballast
/ 3015H rear Ballast weight? #9
I just leave the BH on... No issues so far
Parden my lack of knowledge, but what does TPH stand for?
/ 3015H rear Ballast weight? #12
I have a 3015R. For ballast I have a 55 gallon barrel 85% full of concrete with part of an old differential and assorted random chunks of steel for an estimated ~1300 pounds. So far I have picked up some rather large pieces of hickory trunk with it and was completely stable. As is a bucket FULL of moist dirt. I have some 24"ID by 8' concrete pipes to move, they are about 2200 lbs. I am interested to see how my ballast does with that, I am pretty sure the tractor will pick it up. These pipes are the first thing I have had the opportunity to move that I have a pretty exact idea on weight. My goal is to lift them high enough to get them on a trailer. I'll let you know how it goes.
GMC 2500HD 4wd Service Truck (A63118)
GMC 2500HD 4wd...
2022 Bobcat T66 R - Series Skid Steer (A61166)
2022 Bobcat T66 R...
Better Built 36 Gallon Fuel Cell (A61166)
Better Built 36...
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
2003 Sterling L8500 Series FEC 3216 8 Ton Knuckle Boom Crane Truck (A61568)
2003 Sterling...
UNUSED CFG INDUSTRIAL MX20R MINI EXCAVATOR (A62130)
UNUSED CFG...
