Stihl MS290 not getting fuel?
   / Stihl MS290 not getting fuel? #1
jenrow33
Michigan
Kubota L3400HST
Ok, I’m at wits end here. My Stihl MS290 quit at full throttle the other day and wouldn’t start. Here’s what I’ve done:
1. I have spark and installed new plug
2. New fuel line and filter
3. New impulse line
4. Tank vent not plugged or off
5. New carb kit and full clean including diaphragm
6. New fuel mix
7. New air filter
When I pull for a while, literally nothing, no burp, no chug, nothing. Pull out plug, not wet. When I rebuilt carb after pulling a bit, not really wet either. My guess is not getting fuel, but given what I’ve already done, what am I missing??
Thanks in advance!
   / Stihl MS290 not getting fuel? #2
why are you posting here? maybe better posted in "Lawn & garden" forum? some K dealers sell Stihl, but better directed to a small engine forum good luck
Every tractor person I know owns a chainsaw. Thought someone could help.
   / Stihl MS290 not getting fuel? #4
One way to prove if fuel or other is the source of problem is to squirt some fuel into the combustion chamber, either via plug hole or via the carb.
If it fires and dies you confirmed ignition is OK.
In the carb, did U place gasket on correct side of flapper valve?
Those little flaps need to be able to make contact with the ports so maybe gasket is on wrong side.
Been there done that!
LOL, just rebuild my leaf blower and also did a few wrong assembly moves but I will say all my leaves went to kingdom come yesterday PM, i.e. success!
Hmm...I think it’s assembled right but great thing to double check. Thanks.
   / Stihl MS290 not getting fuel? #7
do you use ethanol free fuel in your small engines? ethanol is frequently the culprit in fuel related issues
   / Stihl MS290 not getting fuel? #8
When you take the spark plug out and hold it against the head & pull....does it make a strong blue spark? If it isn't sparking then it's time to figure out why.
If you have spark, that only leaves the carb, and my bet would either be the flapper valve isn't sealing or the main jet has some crud in it in spite of the your best efforts at cleaning. Sometimes you need to do the carb a few times to get all the orfices open.
luck,
rScotty
   / Stihl MS290 not getting fuel? #9
Compressed air is your friend when cleaning carbs.
One trick I learned was to use spray can oven cleaner to de gunk carbs.
Always have a few cans on hand just 4 that.
Just B sure to rinse thoroughly after de greasing as it is very caustic.
   / Stihl MS290 not getting fuel? #10
I agree with the oven cleaner but be careful with compressed air. What I do for cleaning the small orfices is to strip the insulation off of some stranded copper wire and then unlay one or two small strands. That's what I use to poke down the holes.
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2023 Kubota Z252KH-54 Zero Turn Mower (A55315)
2023 Kubota...
2009 Sterling Derrick Digger Truck (A55973)
2009 Sterling...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
