What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #401
Loading dumpster with old lumber.
   / What else do you do with forks besides lift pallets? #403
I know you are a metal builder but can you not salvage that wood? I have a hard time throwing stuff like that away.
This is stuff I had saved outdoors for years. It was originally sorted and stacked with air gaps between the layers but that did not last long
   / What else do you do with forks besides lift pallets? #404
Oof yeah like dragon I also cringe at seeing usable lumber thrown away. Put it in a pile by the road, with a quick ad on craigslist, and it could be put to use by someone - even if just for firewood (unless it was treated?). Putting lumber into a landfill to rot is among the most wasteful human behavoir I can imagine... Sorry, not intended to be a personal attack in any way.
   / What else do you do with forks besides lift pallets? #405
Oof yeah like dragon I also cringe at seeing usable lumber thrown away. Put it in a pile by the road, lSorry, not intended to be a personal attack in any way.
Not at all! I feel the same way. I already resorted my pile. The stuff going into the dumpster was rotten.
   / What else do you do with forks besides lift pallets? #406
Right! You kill it, you eat it. :D
   / What else do you do with forks besides lift pallets? #407
   / What else do you do with forks besides lift pallets? #408
The forks are spaced perfect to pick up a 32 gallon round trash can, lifting it under the handles. You can pick them up, transport, and set them down without getting off the tractor.
   / What else do you do with forks besides lift pallets? #410
Terry, you are quite the busy beaver!
2016 Kubota U55-4 (A57148)
2016 Kubota U55-4...
BOMAG BW213 SMOOTH DRUM ROLLER (A58216)
BOMAG BW213 SMOOTH...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
2017 Gravely 472 Pro-Turn (A57149)
2017 Gravely 472...
John Deere HPXD (A57149)
John Deere HPXD...
