Considering this new trailer.
/ Considering this new trailer. #2
Just make sure you have enough room to pull forward on the deck so you can get the ramps folded. We had these ramps on a 30' deck over and had plenty of room to pull up before moving back after the ramps were folded. Additionally, at that price you are getting into deck over territory which make loading from the side much easier as well as loading equipment that is 1"+ too wide to make it between the fenders.
/ Considering this new trailer. #3
I'd say go find an Iron Bull equipment trailer with the 4,000 lb rated (each) drive over fenders. You can option the pull out or the flip up ramps. Way more versatile with the drive over fenders. I love mine, it's a beast!
/ Considering this new trailer. #5
221 Rice Trailers 7x2 Powder Coated 14K Equipment Trailer w/ Max Ramps MH3165 | Scott's Recreation
Any experience with this manufacturer? The Max ramps look like a big improvement over the traditional ramp.
Feel free to speak your mind, I'm open to suggestions.
Thanks!
I have a Rice 16' tandem utility 7k. Pretty good trailer, had a support weld break which is somewhat concerning. Easy fix though The powder coating on mine has not held up well. I'll go painted next time. All and all it's a pretty good trailer though.
/ Considering this new trailer. #6
/ Considering this new trailer. #7
Most trailer powder coating stinks!
I've found that powder coating on most large things sucks. It seems to be a good coating process for small parts which can be oven baked with consistent controllable temperatures, but on larger things it must be hard to control the process. It ends up coming off in chips and sheets.
/ Considering this new trailer. #8
I wanted drive over fenders when I bought my equipment trailer just for durability not driving over but I couldn’t find anything with that option. I ended up with just regular fenders but I still have a deckover for abusing.
/ Considering this new trailer. #9
/ Considering this new trailer. #10
/ Considering this new trailer. #11
Agreed. They don稚 get along with truck tailgates like that.
That depends on the trailer and hitch being used.
My ironbull started out with the jack mounted at the front of the deck as shown, IMG_0261.JPG.
Eventually I moved the jack forward to make room for a winch mount as shown, IMG_0300.JPG.
On this trailer with the hitch I'm using I can open the tailgate without hitting the jack.
/ Considering this new trailer. #12
I have no experience with Rice trailers, but would second Rock Crawler's suggestion to get a 102" wide trailer with the drive over fenders. It doesn't look like Rice trailers makes one, but a quick internet search shows that PJ Trailers makes a 14k trailer with drive over fenders and their Monster Ramps which are equivalent to the Max ramps on the Rice trailer.
6" Channel Super-Wide (B6) | PJ Trailers
Car Hauler Monster Ramps | PJ Trailers
I have no idea how the PJ compares in price, but it also has the jack set back at the front of the deck so it does not interfere with your truck tailgate, etc.
Maxx-D and many other manufactures also make 14k trailers with drive over fenders, but I am unsure how many offer the full width fold-flat ramps.
H6X Buggy Trailer | Driver Over Fenders | Maxxd Trailers
/ Considering this new trailer. #13
This the 14,000 gross Iron Bull (sub brand of Norstar trailers in Texas) with the drive over. The jack is in the rear position, but simply unbolts and you move it to the front have plate of you desire.
You can get the flip up ramps, or what I went with is the slide out under deck ramps. The fenders are rated at 4k lbs each. I'm extremely impressed with the build, it's a very well built heavy duty hauler that pulls behind me as smooth as butter even with a 10k lb mini excavator while ripping through the mountains at 70 mph.
I can't say enough good about this thing.View attachment 67230720200915_190021.jpg20200915_190032.jpg
/ Considering this new trailer. #15
I can't say enough good about this thing.View attachment 672307View attachment 672308View attachment 672309
I like that trailer. I can't seem to find it on their website and that attachment you posted doesn't work.
/ Considering this new trailer. #16
That attachment was as picture from the front. I'll try again....
/ Considering this new trailer. #17
Load trail makes a nice trailer also and you can get the drive over fenders....
/ Considering this new trailer. #18
Maybe I'm confused about the brand, but I could swear Load Trail was one of the brands I put on my black list when I was trailer shopping because the welds were garbage and the undersides were unpainted bare steel (several, maybe even most trailers are sold this way).
/ Considering this new trailer. #19
I suspect you will find your trailer is like mine in that you will need to make another mount plate and weld it to the jack if you move the jack to the front. The mount on the front of the deck is higher than the mount on the tongue so if you were to just turn the jack 180 degrees and use the same jack mount plate it will end up extending too low causing the jack foot to be dragging a lot.
/ Considering this new trailer. #20
Thanks!
Check out this thread. https://www.tractorbynet.com/forums/trailers-transportation/391715-new-tophat-20-trailer.html
I bought that trailer almost 3 years ago. I still like it a lot and it is the trailer I use the most out of the 3 that I have. The 2' dovetail makes loading stuff a lot easier. My son in law recently purchased a similar trailer without the dovetail and he said he wished he had it on his. I still wished I had ordered the smaller D-rings.
I see that you are in Maine and probably wouldn't want to get a trailer made in Texas, but this might give you some ideas of what you may want to order on your trailer. As I mentioned in my video, you will be much happier if you order it built the way YOU want it, instead of buying off the lot.
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
John Deere 4440 (A64119)
John Deere 4440...
Caterpillar RM-350/RM-350B/SM-350 Reclaimer Mixer Service Manuals (A63117)
Caterpillar...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
