DK55 Fuel Lift Pump
/ DK55 Fuel Lift Pump #1
jimglassford
Manchester, mi
Kioti DK55, Ford/New Holland 4630
I have been fighting a starting issue with my DK 55. It does not matter if the engine is hot or cold, I have to crank it for a long time. I was wondering if the lift pump is weak or the check valves are leaking by. Does anyone know if there is a check valve in the fuel tank at the pickup point.
/ DK55 Fuel Lift Pump #2
I am not aware of any check valves. Could be a partially clogged line coming from the tank.
The tractor runs fine once started. That would eliminate any fuel restriction. I was wondering if the fuel is running out of the supply line when the tractor is not running. A weak pump would still supply fuel when the engine is running because of the pumping rate. Once shut down, if a check valve is leaking by would drain the supply line until you crank for a while.
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
iDrive TDS-2010H...
2019 K&K Trailer, VIN # 1K9PE2027KA175461 (A65563)
2019 K&K Trailer...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
