DK55 Fuel Lift Pump
   / DK55 Fuel Lift Pump #1
jimglassford
Manchester, mi
Kioti DK55, Ford/New Holland 4630
I have been fighting a starting issue with my DK 55. It does not matter if the engine is hot or cold, I have to crank it for a long time. I was wondering if the lift pump is weak or the check valves are leaking by. Does anyone know if there is a check valve in the fuel tank at the pickup point.
   / DK55 Fuel Lift Pump #2
I am not aware of any check valves. Could be a partially clogged line coming from the tank.
The tractor runs fine once started. That would eliminate any fuel restriction. I was wondering if the fuel is running out of the supply line when the tractor is not running. A weak pump would still supply fuel when the engine is running because of the pumping rate. Once shut down, if a check valve is leaking by would drain the supply line until you crank for a while.
2013 Ford F-250 Crew Cab Pickup Truck (A59230)
2013 Ford F-250...
John Deere Gator (A53317)
John Deere Gator...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2022 WEILER S350 SKIDDER (A60429)
2022 WEILER S350...
KUBOTA KX057-4 EXCAVATOR (A59823)
KUBOTA KX057-4...
