JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,089
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
This is my daughter's BX2200D with a 60" MMM. I bought it used four or five years ago and it has been a good machine (as is my own BX2200 just like it except for tires.)
The Problem: The deck will not raise and lower normally. Hydraulic lift worked fine for years. Now the deck will not lower. It drops no more than 1" (no where near normal cutting height) but raises to about where it always has. Total travel High to Low no more than an inch. It cut fine yesterday as well as one round today on a different property. Since then, I cannot get it to lower at all and no idea what if anything I did after that first round around the property. Neither the drop rate knob nor the cutting height adjustment knob will turn AT ALL. Both seem frozen in place.
So what is going on? Seen this before ? How do I get access to the cam-like mechanism that sets cutting height? My assumption is that is the root of the problem.
What bugs me is that it was just fine all day yesterday and the first cutting round today and then a few minutes later I could not lower the deck.
- I have looked at the suspension linkage and can see no difference between it and my machine.
- Have looked underneath from every possible angle and cannot see anything out of place.
- The lift linkage [1" rod going left-right thru the chassis with levers welded on the outer ends] rotates to the high position normally but while lowering only rotates for downward deck dropping a very small amount and stops. The threaded rod going to the rear with two locked nuts on it is 'normal' in the fully raised position but has 4 or 5 inches of unused slack along the rod when the hydraulics are lowered as much as possible. The lift arms on the 3pt raise and lower normally.
